piston top replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-05-2014, 02:12 PM Thread Starter
OK a lot of post today sorry, OK so I have to replace the piston top got a replacement should I switch out the rings from old one or use the ones that came with new piston?
Spiritwalker is offline
post #2 of 6 (permalink) Old 04-05-2014, 03:12 PM
Always always always use new rings on a new piston, you should also hone the cylinder walls at a minimum as well when doing a piston swap.
post #3 of 6 (permalink) Old 04-05-2014, 05:29 PM
Big Nick's Avatar
If the piston is new second hand as I suspect,I would as Spock says, use new rings,but if budget is lean, you could take the rings of the pistons, place them in the cylinder and check the end gaps. Use the piston to push the rings down the cylinder,about an inch,and make sure that the ring is level in the bore. Then use the ones with the narrowest gap. If a hone isn't available,use a bit of wet and dry sand paper and scuff it up in a circular motion.
Feeler gauges are the tool to measure the end gap, manual will tell you what the min and max gaps are. Cheers SpiritWalker.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #4 of 6 (permalink) Old 04-05-2014, 06:07 PM Thread Starter
Yes its a budget, if the end gap is good itys gonna stay that way. Money is tight and now I need a can chain guide for behind the stator as its chewed up a
Little by where it bends
post #5 of 6 (permalink) Old 04-05-2014, 06:56 PM
Piston Top? That like a Muffin Top?
New piston? New rings, new wrist pin, new snap rings.
Trying to save money now will just cost you more later I've always found.
post #6 of 6 (permalink) Old 04-05-2014, 07:23 PM
agreed KM.
this kind of repair is better done completely, with proper parts replaced will go a long way.
you do NOT want to pull it apart again after a few miles to replace a cheap part you should have done the 1st time.
