chain guide tensioner - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-05-2014, 09:46 AM Thread Starter
Good morning, would anyone have some spare tensoners? Front head. The right one behind the stator pully looks like some of the black by the knuckle is pealed off the rest of them looks fine. Not sure if that would effect anything.
Spiritwalker is offline
post #2 of 12 (permalink) Old 04-05-2014, 09:54 AM
Not sure why you want a new one. Is it making a clacking noise? Is it leaking oil? Can you post a pic? If itsjust some peeling paint why not just pull it, sand it and paint it?
Edit: I'm dumb, guide not tensioner.
post #3 of 12 (permalink) Old 04-05-2014, 10:06 AM Thread Starter
tensiomer
Yes I will take picture, then figure out how to post it give me a few minutes
post #4 of 12 (permalink) Old 04-05-2014, 10:54 AM Thread Starter
OK once I figure out how to resize this picture as it says file size to large I will post a pic of the front engine chain guide
post #5 of 12 (permalink) Old 04-05-2014, 11:18 AM Thread Starter
OK if anyone on forum can text me I can show the picture as I can't figure out why the file size to large.
717-608-3781 thanks name is jay
post #6 of 12 (permalink) Old 04-05-2014, 02:13 PM Thread Starter
OK cannot get the picture to post i have receipts the pic 8x with no luck
post #7 of 12 (permalink) Old 04-05-2014, 03:21 PM
Deviate's Avatar
Host the pic on photobucket, imgur, etc and use the "Insert Image" function on the forum to insert the image using the direct link.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #8 of 12 (permalink) Old 04-05-2014, 05:42 PM Thread Starter
Need a new one saw one on eBay, gonna talk to settler see if it's in good shape is a complete set of can chain guides
post #9 of 12 (permalink) Old 04-05-2014, 06:06 PM
Big Nick's Avatar
The guide your looking at has a triangular plate,secured to the case by two 10 mm bolts, the other end of which, has a spring on a pin mounted in the chain guide housing on the barrel. The one I found in spares has the same wear factor,approaching bare metal. Not sure if these are critical.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #10 of 12 (permalink) Old 04-05-2014, 08:29 PM Thread Starter
As it looks the chain does not ride on it that part just moves the chain kinda passes that part as it sits on the lower sprocket behind the stator
