MCCT conversion - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 04-03-2014, 06:43 PM Thread Starter
MCCT conversion
Hey guys. I'm new to the forums. I've got the same annoying ACCT sounds that many of you have gotten. I recently purchased the TOC MCCTs and plan on swapping them out this weekend.
I went to swap these out as soon as I got them, but as I started to remove the front cylinder ACCT when I saw that the external oil line assembly is attached to it, preventing me from removing it. That one is the one I'm more concerned about as the noise is definitely coming from that side.
So, is it possible to remove the front cylinder ACCT without pulling off the seat and carbs and all that to get to the oil line assembly and remove that? If not, is it necessary to pull the engine out to remove the ACCTs and install the MCCTs?
Thanks in advance.
timochenko is offline
post #2 of 14 (permalink) Old 04-03-2014, 06:59 PM
Concert connoisseur
wib714's Avatar
just take out the screw in the tab holding the oil line, use needle nose vise grips and bend the tab out of the way. you can bend it back if you like but most of us have just left it out of the way and put the screw back in. the oil line is plenty strong enough to support itself there and the tab is not really needed! be sure not to twist the line when you do it but its no problem!!!!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 14 (permalink) Old 04-03-2014, 07:30 PM
X2 on wibs post
post #4 of 14 (permalink) Old 04-04-2014, 07:55 AM
post #5 of 14 (permalink) Old 04-04-2014, 08:37 AM
do we need a 4x?? if so here it is..
4x!!
michiganteddybear is offline
post #6 of 14 (permalink) Old 04-04-2014, 09:01 AM
I'll bid 5X....
Who'll go 6?
post #7 of 14 (permalink) Old 04-04-2014, 09:29 AM
2FAS4U
6X
2fas4u is offline
post #8 of 14 (permalink) Old 04-04-2014, 10:39 AM
Originally Posted by 2fas4u View Post
6X
I'll go X10
post #9 of 14 (permalink) Old 04-04-2014, 11:37 AM
Let's go a full 12 pack.lol
post #10 of 14 (permalink) Old 04-04-2014, 08:21 PM
Concert connoisseur
wib714's Avatar
well if that dont make you feel at ease, good luck pulling the engine for a mcct coversion. LOL
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
Tags
acct , mcct
