need second opinion before i rebuild engine - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-02-2014, 06:28 PM Thread Starter
oriontheblacksmith's Avatar
i need some 2nd opinions from you guys. after a short ride yesterday, i felt hot oil spitting out of the spark plug hole on the back cylinder. i stopped riding and pulled the boot off and it was covered in oil. a friend of mine said that it could be a lot of things that require an engine rebuild (rings, valves ...). i trust him but i dont want to pull the motor if i dont have to. what do yall think??
1985 VN700
$450 ex-basket case
shaved and coastered
dimmer switch replaced
headlight rewired
speedo and tach removed (dont work)
turn signals removed (dont work)
side stand switch removed
new spark plugs
oriontheblacksmith is offline
post #2 of 4 (permalink) Old 04-02-2014, 07:04 PM
Probably just needs the o-ring or seal for the 'spark plug tube', forget what they're called.
You can use the rear axle nut to remove the tube, best to look at the manual first.
post #3 of 4 (permalink) Old 04-02-2014, 07:18 PM
check that oring before digging in deep
michiganteddybear is offline
post #4 of 4 (permalink) Old 04-02-2014, 07:35 PM
yup 99% of the time thats what it is when the o ring fails it puddles up in there and the wind sucks it out there is supposed to be a weep hole on the back of the head so it can drain there instead but they get clogged with road dirt
i wouldn't pull the engine just yet and i am guessing your friend works on american bikes more than jap bikes
post #5 of 4 (permalink) Old 04-02-2014, 11:56 PM Thread Starter
phew, thank goodness. i was worried i'd miss riding in some of this great weather. what should i be looking for when i pull out that sleeve? just a broken o ring?
1985 VN700
$450 ex-basket case
headlight rewired
new spark plugs
post #6 of 4 (permalink) Old 04-03-2014, 01:06 AM
Yup....what they said.......ditto.......btw....we have a smithin thread here now....I built a forge a week ago, made 1 knife from a RR spike so far......c'mon and add yer knowledge to it....Im a newbie....Im lookin to learn....
