GoPro ride and engine thump - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 03-31-2014, 07:47 AM Thread Starter
Got a gopro hero3+, great camera. At the beginning of the clip when i get to the stop light, you can kinda hear the thump I've been talking about on the front cylinder. Sorry about the rattling sound which is the fishing leeder I used to make sure my new camera doesn't become road kill if the mount fails.
The thump goes way when you're going and the bike runs smoothly. Idle jet on the rear?
http://youtu.be/DeDI-04RTGo
post #2 of 24 (permalink) Old 03-31-2014, 10:48 AM
I can hear it even when you get up to speed, and it sounds down low in the engine... i really don't think it is a carb issue, unless no fuel is flowing in there and I am hearing a dead piston moving.
post #3 of 24 (permalink) Old 03-31-2014, 10:54 AM Thread Starter
Definitely no dead piston. She flies. I wasn't even goos'n it in this video. Still, PEOPLE WILL NOT STAY OUT OF THE LEFT LANE!
post #4 of 24 (permalink) Old 03-31-2014, 10:58 AM
I have had mine up to 110 on one piston, and she seamed to scoot along fine, then when I got both working she flew. I had the same noise you do as well.
post #5 of 24 (permalink) Old 03-31-2014, 11:07 AM Thread Starter
Ok, so how do I test this theory? wouldn't this thing be backfiring and all kinda stuff goin' on?
post #6 of 24 (permalink) Old 03-31-2014, 11:57 AM
Goofy, I do not hear well. I watched it twice, sounds like a dead cylinder or small exhaust leak to me. Too much throttle to move away from a stop sign.
You the guy that had trouble with synching? If so I would look for one carb with a plugged pilot circuit.
wmsonta is offline
post #7 of 24 (permalink) Old 03-31-2014, 12:15 PM Thread Starter
So how do I check for a dead cylinder and then can I back blow the pilot?
post #8 of 24 (permalink) Old 03-31-2014, 12:50 PM
Goofy, does the motor USUALLY require a little cranking and nearly always likes a little choke when cold?
Describe how it starts. Mine starts warm instantly, when cold, half choke fires instantly.
wmsonta is offline
post #9 of 24 (permalink) Old 03-31-2014, 12:59 PM
Cylinder short test ... Remove/replace plug wire as it idles, listen for any change. No change, dead cylinder. Would have to remove two plug wires, then replace one for the test, in this case.
Not a fan of backblow. Seems it would create a mushroom cloud of loose crud inside a dirty carb. I now it works in some cases, but anyway .... It can't remove crud, just move it around.
post #10 of 24 (permalink) Old 03-31-2014, 01:20 PM Thread Starter
Mine starts ok cold, sucks starting warm.
Tags
gopro , rattle , thump , vn750
