Cooling fan issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-23-2014, 11:16 PM Thread Starter
Cooling fan issue
Hey gang I need some help identifying a problem with my '97 vulcan.
So I noticed that my fan has NOT been coming on. At first I thought maybe since the cool weather here in Florida was helping the engine stay cool. However, today I rode my bike to work, the weather temperature was in the low 80's and as I was riding I noticed the water temp gauge moving towards the middle. But when I would get stuck in a bit of traffic or stopped at a red light light the gauge needle moved pass the middle and towards the first bar on the HOT side. But as soon as I started to ride the gauge would move back to the middle and at times move closer to the cool side. When I arrived to work and parked the bike I saw the needle move pass the middle and close to the first notch of the HOT side, I pressed the engine switch to off and the fan didn't even come on. Which I felt it should have done so.
Then tonight coming home no issues the gauge never got to the middle, I figure the cool weather kept the bike cool. When I parked my bike in the garage the fan didn't come on.
Any suggestions on why the fan is not coming on. A friend of mine seems to think its a bad thermostat plug. If so, is that easy part to find on the web? About how much am I looking at.
Please help
Thanks,
hacez529 is offline
post #2 of 6 (permalink) Old 03-23-2014, 11:42 PM
Start with the simple stuff. The thermal switch is probably your culprit. on the bottom of the radiator on the left side is a temperature switch with one wire, Touch the wire to ground, if the fan turns on, then your switch isn't working, if it still doesn't come on, unplug the fan and check for voltage on the Blue Wire... If no voltage, apply power to the blue wire and fan should come on. If fan comes on with voltage applied to the Blue wire, then you have a bad relay inside the fuse box and will need to either get a new Junction Box (fuse box) or rebuild your existing fuse box.
post #3 of 6 (permalink) Old 03-23-2014, 11:52 PM Thread Starter
Thank you Slim. I appreciate your quick response and feedback. I will check it out tomorrow. Thanks again
hacez529 is offline
post #4 of 6 (permalink) Old 03-23-2014, 11:52 PM
When my fan stopped last summer, it was a loose spade connector in the plug at the junction box.
I pulled the spade out of the plug and pinched it tighter with pliers. Not sure what color wire, but find it (wiring diagram) and give it a wiggle while the sender wire is grounded, will tell you right away if that's it.
post #5 of 6 (permalink) Old 04-14-2014, 12:17 PM Thread Starter
So I had the bike checked out for the fan issue. Fan works, replaced fan switch just in case however it's still not work when the bike gets hot. Based on what I have read it's then the fuse box. Does anyone know where I can buy one?
hacez529 is offline
post #6 of 6 (permalink) Old 04-14-2014, 01:16 PM
Check with/pm kc2dgq or New_Rider9984
:smiley:th
