Torqued head gaskets then had to remove them.. thoughts? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-11-2014, 01:14 PM Thread Starter
Hello all,
Well i got the engine back together on my 1985 vn700, but before i put the head covers back on, i looked at the timing and didn't like what i saw, so i pulled the heads back off. Did i ruin my brand new head gaskets?? They were torqued, no heat or anything? Do i need to order new ones?? Thoughts?
Thanks all!
1985vn700 is offline
post #2 of 8 (permalink) Old 03-11-2014, 02:51 PM
Should be fine, won't know unless you try them. I'm assuming no visible damage when u removed them
post #3 of 8 (permalink) Old 03-11-2014, 03:53 PM
I replaced my water pump on my volvo this weekend and kept getting leaks. Only had one gasket so cut the other two tries out of a cereal box. That seems to have worked great so far.
Can you do that with a head gasket if you needed too? Just wondering.
post #4 of 8 (permalink) Old 03-11-2014, 04:13 PM
Big Nick's Avatar
Head gaskets.
Originally Posted by 1985vn700 View Post
Hello all,
Thanks all!
If you didn't buckle or damage them,and they go back the way they came off,all should be good.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #5 of 8 (permalink) Old 03-11-2014, 04:20 PM
Big Nick's Avatar
To Goofy foot. No cereal box head gaskets allowed. If your stuck and need a week or two, you could try a product called Chemi weld in the Radiator,may hold for a while. Allowing the head is still on.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #6 of 8 (permalink) Old 03-11-2014, 04:38 PM
Never put any of that crap in your radiator! Does more harm than good really.
Nope your head gaskets have metal surfaces around the cylinder that are critical.
post #7 of 8 (permalink) Old 03-11-2014, 05:55 PM Thread Starter
hmm... thanks for all the replies everyone!! some people have told me that since they were torqued down, they wouldn't use them again, and would buy new ones.. i really don't wan't to buy new ones (again) but i'd sure hate to put the engine back in just to find out i have to pull it again and get new head gaskets anyway.. ugh...
post #8 of 8 (permalink) Old 03-11-2014, 06:04 PM
Dr. Vulcanstein
jadabull's Avatar
I would re use them, just make sure you put em back on the same way they came off ie, don't swap or flip them.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
