Open temp gauge RPM housing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-10-2014, 01:30 PM Thread Starter
ok so when I get to this point, how do I get inside? I see where everything disconnects.
post #2 of 8 (permalink) Old 03-10-2014, 01:38 PM
The speedo is a factory sealed unit....I've read at least one person carefully prying at the retaining ring to gain access inside.....
The tach, unsure, but would expect to be factory sealed also.
hth
post #3 of 8 (permalink) Old 03-10-2014, 01:47 PM
https://drive.google.com/file/d/0BwM...it?usp=sharing
here is a write up I did of getting inside your speedo, same thing applies to the tac
post #4 of 8 (permalink) Old 03-10-2014, 01:49 PM
Heh heh he said getting inside your speedo
post #5 of 8 (permalink) Old 03-10-2014, 02:17 PM Thread Starter
http://www.scribd.com/doc/29069304/Gauge-Re-Freshening
Your description starts with "after you get inside your speedo" I neeed the part about getting inside the housing.
post #6 of 8 (permalink) Old 03-10-2014, 02:24 PM
post #7 of 8 (permalink) Old 03-10-2014, 02:25 PM
if that doesn't work let me know.. I have about 20 documents I have written about getting inside inside the dash.
post #8 of 8 (permalink) Old 03-11-2014, 12:24 PM Thread Starter
ok just need to test everything thoroughly until I get to the point where I need to get to the actual gauge I guess. Didn't want to drimmel if not necessary. Hell if I could find a decent aftermarket gauge I'd get one. Most suck or are too expensive.
Tags
rpm , rpm gauge , temp gauge , temperature
