Equal length no-goat exhaust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 02-27-2014, 07:24 PM Thread Starter
Crowley
crowley1027's Avatar
Found a shop ~3 minutes away from my house that'll bend pipe for me. I'm going to eliminate the goat, and lengthen the shorter pipe with two 90s, to pop it out the other side with the longer pipe. Pipe at the scrap yard is .50 a lb, I paid five bucks for a ten foot section. Got two 8" baffles to pass inspection.
Only concern is fitting one pipe above/below the other on the same side.
I'm excited!!
crowley1027 is offline
post #2 of 21 (permalink) Old 02-27-2014, 07:35 PM
You shouldn't have any issues with the fitment.
Many have done the same thing & there's aftermarket setups the same way.
post #3 of 21 (permalink) Old 02-27-2014, 07:38 PM
The only thing I can think of is you might lose the center stand if you don't plan ahead.
post #4 of 21 (permalink) Old 02-27-2014, 07:44 PM Thread Starter
Crowley
I'm sure I can fab a bracket or pipe around it
post #5 of 21 (permalink) Old 02-27-2014, 08:14 PM
If its just 1 7/8 pipe goin thru there, should be fine...I had to remove the cent stand only when i was runnin my Streetglide muffs...
You gonna slash cut the ends on em ?....
post #6 of 21 (permalink) Old 02-27-2014, 08:22 PM Thread Starter
Crowley
After I inspect it. Need some sort of baffle or muffler to pass inspection. I thought stock pipes were 1 3/4 I'd?
post #7 of 21 (permalink) Old 02-27-2014, 08:35 PM
...mebbe the ID is....but the outside is 1 7/8....thats why Harley stuff fits so nice...
V-Twin Mfg has really nice glass wrapped 8" baffles for cheap....
I put these in my fishtails....
http://www.vtwinmfg.com/webapp/wcs/s..._143634_143635
post #8 of 21 (permalink) Old 02-27-2014, 08:35 PM Thread Starter
Crowley
Micrometer says 1.5 ID
post #9 of 21 (permalink) Old 02-27-2014, 08:40 PM Thread Starter
Crowley
It's okay though, last 10" I'll just sleeve with larger pipe and weld.
post #10 of 21 (permalink) Old 02-27-2014, 09:20 PM
How about 2 screamin eagles or sporty muffs on the same side 1 above the other? Was thinking about that.not gonna tell ya about Wolfie's idea until I plan it out.I know Wolfie remembers
