balancer dampers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 28 (permalink) Old 02-25-2014, 11:57 AM Thread Starter
Angry balancer dampers
hi guys, is it possible to change the balancer dampers without pulling the engine out.
all the best Steve
STEVEUK is offline
post #2 of 28 (permalink) Old 02-25-2014, 12:17 PM
Mmmm......nope sry
But it isnt as hard as you think it is going to be and the job doesn't take all that long to do.
post #3 of 28 (permalink) Old 02-25-2014, 12:23 PM
No.
To access / replace balance dampers (6 rubbers) you must pull the Stator / Balance Damper cover...
...the left frame prevents cover being pulled w/o pulling/or just tilting the engine.
btw: Balance damper bolt is LH threaded bolt.
post #4 of 28 (permalink) Old 02-25-2014, 12:50 PM Thread Starter
Okay thanks for the info, i thought the engine would have to come out, there is a knocking coming from the bottom of the engine louder if you stand on the left side of the bike is there anything else that might cause this apart from the dampers or bigends.
steve
STEVEUK is offline
post #5 of 28 (permalink) Old 02-25-2014, 01:07 PM
Dr. Vulcanstein
jadabull's Avatar
If its a ticking or clacking sound it would suggest the acct's or lifters a knock as you say would suggest the dampers or rod bearings (big ends) or possibly a stuck valve, either way you should not run the bike till problem is fixed. Does your bike vibrate more then usual? Pulling the engine and fixing the dampers really isn't that difficult as mentioned above.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 28 (permalink) Old 02-25-2014, 01:24 PM Thread Starter
i did put some more tension on the acct's but the knocking is at the bottom of the engine, the oil presure light goes straight out when you start it, with a bigend going i would expect a drop in presure, as for vibration i dont know when i got the bike the carbs were removed along with other parts so all i have done is put the carbs back on and got it running.
STEVEUK is offline
post #7 of 28 (permalink) Old 02-25-2014, 01:26 PM
steve
Advise you not to run the engine until diagnosed...
if the knock is your Balance damper rubbers, the Balance damper itself can/will become damaged (nubs break off).
pics of my damage are in my Avatar Photo Album....
post #8 of 28 (permalink) Old 02-25-2014, 04:47 PM
Have you checked your oil? If the dampers have failed you should see rubber bits in your oil screen when you drain it.
Also, the engine doesn't have to come completely out. Disconnect everything as if your going to remove it & you will be able to cock it to the right enough for the stator case bolts to be removed. Then you have access.
post #9 of 28 (permalink) Old 02-25-2014, 04:52 PM
Dr. Vulcanstein
jadabull's Avatar
If you do this procedure, or a full engine pull for that matter make sure you do not bang the shift shaft on anything (frame), if you do you can bend the shaft or ruin the oil seal which means a case split for repair.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #10 of 28 (permalink) Old 02-26-2014, 11:21 AM Thread Starter
Well drained the oil the screen was trashed some of the mesh was in the oil drain cap was at the end off the passage way, i found 1 piece of rubber looked to be from on of the 2 damper with the grooves. started taking the bike to bits to remove the engine.
steve
STEVEUK is offline
