piston rings needed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 31 (permalink) Old 02-24-2014, 02:30 PM Thread Starter
piston rings needed
Hello all,
I am having a difficult time trying to find a set of piston rings for my 1985 kawasaki vn700. i found one NOS set, and i need one more... Any advice/tips/suggestions?? Thanks!
1985vn700 is offline
post #2 of 31 (permalink) Old 02-24-2014, 02:49 PM
Do you have a micrometer? I'm wondering if you can measure them for me, perhaps we can find something else that uses the same size rings. The bore should be ~82mm if I recall. If you can post the rest of the measurements for the rings I'll look around and see if Ican find something that will work for you.
post #3 of 31 (permalink) Old 02-24-2014, 02:54 PM Thread Starter
Awesome! I will check tonight after work! Thanks!
post #4 of 31 (permalink) Old 02-24-2014, 03:09 PM
Well I ran into a similar problem rebuilding a cx500. I couldn't find rings to save my life. Come to find out, if you machined the grooves in the pistons just a little wider you could use a readily available set of rings from a Toyota Camry. I'm thinking if nothing else matches up there might be a similar solution available for this.
post #5 of 31 (permalink) Old 02-24-2014, 03:21 PM
Dr. Vulcanstein
jadabull's Avatar
http://www.ebay.com/itm/KAWASAKI-130...ca3947&vxp=mtr
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 31 (permalink) Old 02-24-2014, 03:27 PM
He needs for a VN700 not a 750, they are different sizes.
post #7 of 31 (permalink) Old 02-24-2014, 03:27 PM Thread Starter
I appreciate the help, but it looks like those are 750 rings.
post #8 of 31 (permalink) Old 02-24-2014, 03:38 PM
Dr. Vulcanstein
jadabull's Avatar
My bad man, didn't even notice the "700"....
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #9 of 31 (permalink) Old 02-24-2014, 05:35 PM Thread Starter
No worries dude!
post #10 of 31 (permalink) Old 02-24-2014, 05:52 PM
I hope there is a solution readily available, when I go to rebuild my 700 I am sure I'll have to look at the rings.
