engine pull - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 02-23-2014, 06:29 PM Thread Starter
engine pull
doin an engine pull over here got a few questions if anyone has the time i was wondering how the air box comes out or if theres a trick i dont know about to get the carbs out ive messed around a lil but figured id ask do you disconnect the cables before the carbs are removed also i havent got this far but i was wondering the easiest way to disconnect the shaft drive got the tank off and everything unhooked that i can just looking for some advice from someone who has been there or knows what i am askin thanks o and i am pulling the engine to replace the shift linkage and its a 2001
"So, Doc, look at this engine. I open its heart, take valves out, fix 'em, put 'em back in and when I finish, it works just like new. So how come I get such a small salary and you get the really big bucks, when you and I are doing basically the same work?"
The surgeon paused, smiled and leaned over and whispered to the mechanic ...
"Try doing it with the engine running!"
thedevilsrighthand is offline
post #2 of 24 (permalink) Old 02-23-2014, 07:01 PM
Dr. Vulcanstein
jadabull's Avatar
Not sure if there's a trick to the airbox, I tried to finesse it out, after about 5 minutes got pissed, I started turning green muscles were tearing through my clothes and I ripped the fuqer out.
Leave the carbs on the motor, but disconnect all the cables, its easiest to get to the choke cable from the right side of the bike. Skinny needle nose and skinny flathead will be your friend.
Some people leave the front bevel gear on, I took mine off, I think its 7 8mm bolts. Unscrew bolts wiggle the gear box some and pull out and to the right a little, don't forget to remove the aluminum rod from the bevel gear so it doesn't hang up on the frame and get bent.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 24 (permalink) Old 02-23-2014, 07:16 PM Thread Starter
it didnt take me long to get flustered thats usually when i break something so i figured id get some advice first i read some on your engine pull post were having good weather here lately and its making me anxious
post #4 of 24 (permalink) Old 02-23-2014, 07:32 PM
Dr. Vulcanstein
jadabull's Avatar
Also, I don't have a manual for the bike so I downloaded the first page for engine removal that way I could use it for a checklist. The only problem I had is that I used a big automotive hydro jack for it to rest on and it wouldn't really lower enough to clear everything, I would suggest using a smaller jack if you can.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 24 (permalink) Old 02-23-2014, 08:51 PM
if you have the bike on level pavement you can wiggle a cinder block under it and set another one on the right side it is the perfect height set them long ways sticking out the right side of the bike
pull off the bevel gear
leave the throttle cables attached to the carbs but pull the choke cable off
once you have the motor slid out sitting on the cinder blocks you can then pull the carbs easy
oh and that crappy air box stays there as the motor comes out from under it when putting the motor back in just get some string and tie the air box up so you can work under it
post #6 of 24 (permalink) Old 02-23-2014, 09:50 PM Thread Starter
i dont have a manual yet paper or electronic prolly should get one of thoes i figured me and a buddy would try to muscle it out first but ill remember that
post #7 of 24 (permalink) Old 02-23-2014, 09:57 PM Thread Starter
that sounds great man i would have never though of that im gonna have to look up a pic of this bevel gear im not sure where exactly that is and that air box is gonna have to go when its out has anyone put pods on there carbs what size do i need for the bolts on the removable frame piece
post #8 of 24 (permalink) Old 02-23-2014, 10:09 PM
Got me interest as I'll be pullin a motor soon
OleDirtyDoc is online now
post #9 of 24 (permalink) Old 02-23-2014, 10:28 PM
Dr. Vulcanstein
jadabull's Avatar
Download repair manual here....http://www.mediafire.com/?mj7z818grhbdy3x
The front bevel gear is the gearcase by the left rear side of engine, has a circular Chrome cap on it.
You can get rid of the air box and install pods (k&n's or emgo's). Go to the search bar up top and check out "earshave".
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #10 of 24 (permalink) Old 02-24-2014, 06:30 PM Thread Starter
ok will have to download it might take awhile computer is slow but are you talking about the 4 bolts after the crome cap to unhook the drive
