Temp gauge average? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 02-23-2014, 05:38 AM Thread Starter
Big Nick's Avatar
Cool Temp gauge average?
Hi guys I'm a bit concerned over Jada's engine failure and at least one other I know of. My temp gauge works and runs up to about half way, and the fan comes on and stays there.
My question is for those who have great reliability, and may also have bought one of these bikes new, what is the normal behaviour readings of the temp gauge on the VN in warmer weather?
Do you see the operation of the thermostat visually on the gauge?
Does your Gauge stay in the lower specified region, within the two lines on the left of the scale?
What's normal?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 18 (permalink) Old 02-23-2014, 09:29 AM
while I cant help with the 'owned since new', I can feedback about operating temps in warm climates.
SW florida here, and my bike shows the same temp behaviour as yours.
Mine will occasionally run fan for a few minutes when I first shut it off as well, if its fully warmed up.
in stop/go traffic I have seen mine get just a bit to the hot side of the center of the gauge, but it does not go over
michiganteddybear is offline
post #3 of 18 (permalink) Old 02-23-2014, 10:40 AM
Mine has been the same in Phoenix, AZ......in stop n' go summer traffic fan comes on till I run out of Stop lights.
hth
post #4 of 18 (permalink) Old 02-23-2014, 11:09 AM
Mine, bought new, never went past the half mark (half being the middle of the gauge, needle running straight with direction of bike)
Once or twice it went slightly to the right when stuck in traffic. I never really heard the fan until I turned off the bike. (Where it ran 30 or so seconds before shuttering off)
As long as your bike doesn't run in the red zone I'd not be worried.
post #5 of 18 (permalink) Old 02-23-2014, 12:01 PM
Dr. Vulcanstein
jadabull's Avatar
Just for the record I never had any temperature issues. My bikes temp needle always stayed to the right and climbed slightly when at a traffic light, and quickly cooled back down once I was back to speed, I checked coolant level every day before my first ride and never had to add coolant. When I had my engine failure the bike gave no signs whatsoever, it let loose without warning after the circlip somehow slipped off the impeller shaft.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 18 (permalink) Old 02-23-2014, 12:37 PM
Melissa's fan didn't work and she never came above halfway unless in traffic
post #7 of 18 (permalink) Old 02-23-2014, 02:00 PM
2006 owner since new.....the fan only really comes on at stops when it's above 90 out. The fan kicks in at about half the guage range and the needle has never gone above half for me.
post #8 of 18 (permalink) Old 02-23-2014, 05:02 PM Thread Starter
Big Nick's Avatar
Thanks.
I can breath a sigh of relief, my bikes temperature behaviour is normal.
This site, and you guys are very helpful.
Thanks for the feed back, your are a good bunch.
Jada, I'm sorry if I offended you in any way,this was not my intent.
My reference to your tragic engine problem, was about what I feared, I may be faced with at some point.
That being said,I'm simply going through the process of elimination in my bike.
A: Check all cooling equipment,within reason.
B: Ensure all Timing chains and tensioners are, Right.
C: Premium oil and good filter,in engine.
Parts A and C being true and correct, I'm now becoming hyper critical of any cam chain noise, so manual timing chain adjusters are fully on the cards, and maybe a retention or replacement of the upper morse chain tension springs.
Have a good day.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #9 of 18 (permalink) Old 02-23-2014, 05:09 PM
Dr. Vulcanstein
jadabull's Avatar
Have a good day.
No worries brother, I just didn't want anybody mislead and thinking my problems were coolant/overheating related.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #10 of 18 (permalink) Old 02-23-2014, 07:31 PM
A lotta guys dont "burp" their engines...this is needed whenever the bike is laid on its side...an unburped bike will run at 3/4 the gauge or more consistantly, wheras the same engine properly bled, will never go over half....
