oil change - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 02-23-2014, 02:03 AM Thread Starter
oil change
why can I only get 3 quarts of oil in my motor with filter change the manual says 4? to top of sight glass
fosterfarrier is offline
post #2 of 11 (permalink) Old 02-23-2014, 02:15 AM
manual says 4 Liters with oil Filter which is 4.22675 Quarts with oil filter, it would be just a little over 3 quarts of oil drained out,
post #3 of 11 (permalink) Old 02-23-2014, 01:34 PM
also, make sure you have bike on side stand.
I get almost 1 gallon out when I drain mine (warm oil, on side stand)
post #4 of 11 (permalink) Old 02-23-2014, 01:52 PM
4 quarts is a gallon dude... so a little over three quarts would be almost a gallon
post #5 of 11 (permalink) Old 02-23-2014, 02:46 PM
2000 VN 750 Senior Member
Ah, but if it is really only a little over three quarts it would be closer to 3/4 of a gallon, Dude.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #6 of 11 (permalink) Old 02-23-2014, 03:31 PM
depends how much he means a little over 3 quarts... but still the Filter holds one quart, and the whole bike holds just a little over 4 quarts,
post #7 of 11 (permalink) Old 02-23-2014, 03:47 PM
yea, I know 4 qts is a gallon.. I just didnt feel like typing 4 qts.
however, if I were to try to put a quart of oil in my filter.. I would have 1/2 a quart on the ground... our small filter (even the larger filter thats used by some) wont hold a quart.
post #8 of 11 (permalink) Old 02-23-2014, 03:54 PM
oops, fergot i upgraded to a larger filter.
post #9 of 11 (permalink) Old 02-24-2014, 08:39 PM
Crap, I WAS in 5th gear.
The VN750 does not hold 4 liters of oil, or it would be overfilled-- despite the 4.0 L casting mark on the engine. It's more like 3.5 quarts, but you need to use the sight glass.
Kelly2001 is offline
post #10 of 11 (permalink) Old 02-24-2014, 09:26 PM
Kelly is correct....I usually put in 3 qts....run it some, let it sit, then add to where I like it....to the top of the sightglass (which I dont do) is about 3.60 qts.
