Exhaust stud broken at pipe - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 62 (permalink) Old 02-16-2014, 01:51 PM Thread Starter
These things really rust up. I suppose this is a pretty regular problem. I've been soaking it with PB and putting vice grips on it but no luck extracting yet. Just more soaking???
-Robert
RobertGary1 is offline
post #2 of 62 (permalink) Old 02-16-2014, 02:04 PM
If you can try using a file to flatten out two sides of it. That will give you something more to grab on to. Also when you have the vice grips on try tapping the stud with a hammer. Vibration is really helpful for loosening thing up.
post #3 of 62 (permalink) Old 02-16-2014, 02:10 PM
Crowley
crowley1027's Avatar
If there is nothing delicate around it, blast it with a propane torch. Then vise it and crank.
crowley1027 is offline
post #4 of 62 (permalink) Old 02-16-2014, 02:10 PM
Could try welding a nut on the end?
post #5 of 62 (permalink) Old 02-16-2014, 02:47 PM Thread Starter
I have an extractor set but it seems to be between two sizes. It's really on there too.
I'm building highway pegs per Wolfies design. I got them set up how I want them but now I new to fix this.
post #6 of 62 (permalink) Old 02-16-2014, 02:51 PM
Crowley
Go with the smaller of the two sizes? I'm a fan of torching, blasting with pb, tapping with a hammer, and cranking
post #7 of 62 (permalink) Old 02-16-2014, 02:53 PM Thread Starter
I'm a bit worried about hitting it with a torch with all the plastic and wiring in the area.
post #8 of 62 (permalink) Old 02-16-2014, 02:55 PM
I've never had to torch an exhaust stud. Most of the time a few hammer swings does just fine.
post #9 of 62 (permalink) Old 02-16-2014, 05:32 PM
if you have to drill it make sure to use a cobalt drill, they will cut better under load. i have a spare set of manifolds to do myself
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #10 of 62 (permalink) Old 02-16-2014, 06:16 PM
Since yer talkin hiway pegs/fwd controls, assuming its the front pipe...I suggest removing the entire manifold from the head, and soaking it in brake fluid a cupla days....
