clacking noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 02-13-2014, 11:37 AM Thread Starter
clacking noise
First I'd like to thank everyone for their help on getting my wife's bike started, it starts and idles on it's own, but I noticed a clacking noise coming from the front cylinder it comes and goes, the p/o installed a set of V&H pipes, but I don't know if re-jetted, could this be the problem ? thank you.
rkama354 is offline
post #2 of 9 (permalink) Old 02-13-2014, 11:44 AM
Sounds like your auto cam chain tensioner(acct).read about making a manual one(mcct) in the Vulcan verses.first look up the Grambo trick
post #3 of 9 (permalink) Old 02-13-2014, 12:02 PM Thread Starter
Thanx OleDirtyDoc, I will try this I am hoping it works.
rkama354 is offline
post #4 of 9 (permalink) Old 02-14-2014, 07:55 AM
Question
Is this, one clack, or several then it stops?
Hot .. cold?
Reason I ask, .. Mine will give one clack and a sneeze from the front carb on warmups if I don't keep the idle up. If I take off before warmup, it will do it as I'm riding also.
I'm assuming it's one intake valve on the front cylinder that's sticky when it's cold. Not much else it could be in my case.
I put some Seafoam in the oil about 1000 miles back, no change except it only happens if the rpms get too low during warmup. Before that, it was happening randomly during rides.
The sneeze in the carb always coincides with one clack from the front cyl. Noise from the excess slack being taken up in the rocker arm clearance, created by the valve being stuck open momentarily.
post #5 of 9 (permalink) Old 02-14-2014, 09:51 AM
Dr. Vulcanstein
jadabull's Avatar
Hot .. cold?
I always had that same sneeze. Could feel it on my right knee if I had shorts on.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 9 (permalink) Old 02-14-2014, 10:38 AM
This one is on the left, front carb.
post #7 of 9 (permalink) Old 02-14-2014, 01:02 PM Thread Starter
Well she starts up and sounds good, then when I give it a little throttle the clacking starts, after about a couple of minutes it stops, I don't let it run that long in case it's something serious.
rkama354 is offline
post #8 of 9 (permalink) Old 02-14-2014, 01:27 PM
As Ole Doc said... try the "Grambo Trick" if that cures it, look into making a set of MCCTs or getting a set of TOC MCCTs...
post #9 of 9 (permalink) Old 02-15-2014, 03:40 AM
Good advice !
