Rattle? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 02-09-2014, 11:46 PM Thread Starter
Big Nick's Avatar
Cool Rattle?
Well I finally got the 86 VN 750 mobile, and have noticed a rattle under acceleration. I'm assuming it's pinging, perhaps too far advanced, any other suggestions?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 23 (permalink) Old 02-10-2014, 12:09 AM
A VN750 raffle ?...Cool !!!....how much and where do I send ?.....(jk)
....rattle, eh....check all yer tin and plastic covers first.....could be vibration....Ive also heard detonation sound like "rattle" (pinging)....try fillin up with a tank of high test and see what happens....
Also, after a 200mi or so ride, check yer plug condition and report back...severe detonation will show on the plugs...can also put a hole in your piston....
post #3 of 23 (permalink) Old 02-10-2014, 12:09 AM
Dr. Vulcanstein
jadabull's Avatar
Did you make sure to get all the exhaust clamps tightened down?
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #4 of 23 (permalink) Old 02-10-2014, 08:30 AM Thread Starter
Big Nick's Avatar
Clamps are tight.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #5 of 23 (permalink) Old 02-10-2014, 09:31 AM
Most times a rattle is something external, heat sheild, licence plate, etc.
Engine wise can be a loose cam chain, but rarely is it detonation. Never have seen a case of that here. (So you'd be the first)
Sure your fuel is good?
post #6 of 23 (permalink) Old 02-10-2014, 09:39 AM
Check your saddle bags for rattle snakes...
LibertyPilot is offline
post #7 of 23 (permalink) Old 02-10-2014, 10:16 AM
x2,,,
wmsonta is offline
post #8 of 23 (permalink) Old 02-10-2014, 11:22 AM
How bad of a Rattle is it ?
post #9 of 23 (permalink) Old 02-10-2014, 03:41 PM
Mine used to sound like a tin maraca. Turns out, it's the gas tank. If I loosen the front bolts slightly and then yank up on the tank while I'm sittin on the bike and tighten it under the pull, it comes off whatever it is plinking against. Bike even seems to run better in my little head.
post #10 of 23 (permalink) Old 02-10-2014, 03:48 PM
mine had a horrible rattle or 2..
one was solved when I yanked my rattling glove box off the back
other when I tighted my chin strap on the helmet more to hold my head together tighter
