Oil change question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 38 (permalink) Old 02-06-2014, 12:32 PM Thread Starter
kemen3's Avatar
Oil change question
Every spring I change my oil. Last year I Thankbarely rode it all because of an injury. Maybe a 100 miles. Should I still go ahead and change the oil? Thanks,
kemen3 is offline
post #2 of 38 (permalink) Old 02-06-2014, 12:40 PM
Dr. Vulcanstein
jadabull's Avatar
I would, it may be ok but ide rather spend $17 for piece of mind. viscosity of the oil can still break down some when sitting. The oil compound itself doesn't actually "break down" as the chemical makeup of oil stays pretty sturdy, but what can happen is contaminants from the combustion process and eventually lead to sludge. Maybe not in your case since it was only ridin about a hundred miles but would be best to change anyway.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 38 (permalink) Old 02-06-2014, 12:44 PM
post #4 of 38 (permalink) Old 02-06-2014, 12:51 PM
I'm either leaking or burning enough so my oil is always fresh. These are two cycle engines right? I just mix a cap full in with my gasoline and off I go. Fill up the left side with radiator fluid and she's purrin'. Had to put the battery in the saddle bag cause I couldn't find any place it would fit. It's charging ok cause when I'm going, the charge goes up from 0 to 60 volts most times, if I'm on a highway.
My only problem is that every time I shift gears the bike stops. If I then step or pull on the brake it drives ok but the speedo is off and only reads 13.5. I love my bike though and plan to get a license for us soon.
post #5 of 38 (permalink) Old 02-06-2014, 12:53 PM Thread Starter
kemen3's Avatar
I will do that. Thanks
kemen3 is offline
post #6 of 38 (permalink) Old 02-06-2014, 12:55 PM
Dr. Vulcanstein
jadabull's Avatar
Sounds to me by the problems your describing you seem to have put your rear wheel on backwards. Easy fix!
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #7 of 38 (permalink) Old 02-06-2014, 02:59 PM
Ring a ding ding
post #8 of 38 (permalink) Old 02-06-2014, 05:01 PM
Chasin' the blacktop
Spencer1's Avatar
Sarcasm at it's finest,,, love it.
North Georgia
Spencer1 is offline
post #9 of 38 (permalink) Old 02-06-2014, 06:03 PM
....wiseazz muthafuka...lol....dont do this to new guys, lol......
I change my oil when it needs changin....I dont go by milage....I go by condition....
post #10 of 38 (permalink) Old 02-06-2014, 11:28 PM
Me too cause Melissa used to hate speedo cables.stopped working in late Sept.when I removed the front noticed the end sheared offa the cable.also the blinkers stopped working.noticed the blinker relay was melted.
