exhaust stud? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 01-18-2014, 06:05 PM Thread Starter
exhaust stud?
all the parts sources list the studs as 8mmx25 or 30mm but do not list the thread pitch. im planning on swapping manifolds that i had powder coated. mine are currently stripped, bent and i know those suckers will break as soon as i put a wrench on them
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #2 of 20 (permalink) Old 01-18-2014, 06:34 PM
Are you looking for the studs to mount the manifold to the bike or the exhaust to the manifold?
post #3 of 20 (permalink) Old 01-18-2014, 06:34 PM
Dr. Vulcanstein
jadabull's Avatar
I think they are a 2.5mm, ill check when I get home if it ain't answered beforehand.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #4 of 20 (permalink) Old 01-18-2014, 06:48 PM Thread Starter
both, i have a pair of manifolds that are being powdercoated and i want to replace studs and gaskets at the same time. i may use allenhead bolts if i can nail down the correct thread pitch. i had taken the cruisers off to put the crashbar on and things got ugly when the exhaust went back on. never touched it since then and its not leaking but im planning a multi state trip this summer and dont need potential problems
this 85 i bought has been good to me so i want to return the favor. i just sent a spare stater ti tpe for rebuilding.
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #5 of 20 (permalink) Old 01-18-2014, 07:41 PM
I think theyre coarse thread...I swapped my old exhaust nuts with Eng chrome acorns, lol (non metric) If they were fine, wouldnt have worked...12mm wrench or 1/2" I believe....
post #6 of 20 (permalink) Old 01-18-2014, 07:52 PM Thread Starter
i found one of the old studs and apear to be 8mmx1.25 mm pitch. ill confirm that with the tap and die set and order the 16 bolts i need
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #7 of 20 (permalink) Old 01-18-2014, 08:00 PM
Ndr
Yeah, they are the 1.25 pitch thread. I just ordered a bunch of new Acorn nuts from Grainger to put all mine back together.
Ndr is offline
post #8 of 20 (permalink) Old 01-18-2014, 08:21 PM Thread Starter
thanks, now i can order ereything tonight
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #9 of 20 (permalink) Old 01-18-2014, 10:10 PM
you only need 12 bolts 4 for each manifold and 2 for each pipe
post #10 of 20 (permalink) Old 01-18-2014, 10:18 PM Thread Starter
i found a place to get each size for about 10 cents a bolt shipped, i got 25 of each
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
