Cylinder Squeak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 32 (permalink) Old 01-15-2014, 11:33 AM Thread Starter
Cylinder Squeak
Hey there folks -
So, every time I start my bike, and pretty much whenever it's running, there's a squeaking sound akin to a lower scale squealing belt on a car. This sound is coming from the top of the rear cylinder, and having just replaced my ACCTs, it's driving me nuts. Any ideas?
Brickstack is offline
post #2 of 32 (permalink) Old 01-15-2014, 11:38 AM
Maybe a timing chain roller?
How about the reed valve?
post #3 of 32 (permalink) Old 01-15-2014, 11:58 AM
Leaky sparkplug or head gasket?
post #4 of 32 (permalink) Old 01-15-2014, 12:50 PM Thread Starter
It could be any of those - It almost sounds like the piston is pushing air out of the cylinder through a small hole. However, the engine responds well to throttle and pulls well. Not really sure. I'll take a video soon and put it up on youtube.
post #5 of 32 (permalink) Old 01-15-2014, 12:56 PM
Dr. Vulcanstein
jadabull's Avatar
Have you done any recent work to your engine, had it apart at all?
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 32 (permalink) Old 01-15-2014, 12:59 PM Thread Starter
Nope, not yet. This is my first bike actually, and have gotten my hands dirty only by changing the oil and lubing the final drive splines/driveshaft assemblies. I also added some MCCT recently, although I can't remember if the squeak was there before or after adding those.
post #7 of 32 (permalink) Old 01-15-2014, 01:05 PM
Originally Posted by Brickstack View Post
Hey there folks -
If the noise was not there before replacement, I would pull it back apart. Not run it. More experience should be here soon.
wmsonta is offline
post #8 of 32 (permalink) Old 01-15-2014, 03:32 PM
Dr. Vulcanstein
jadabull's Avatar
If it wasn't making the noise before you did the mcct upgrade I'm thinking maybe you've tightened the cam chain adjustment too much, putting too much tension on the chains and the cam bearings might be torqued.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #9 of 32 (permalink) Old 01-15-2014, 03:43 PM
thats what i am thinking too easy way to find out is to loosen the mcct up and see what happens and do it quick before you damage the cam journals you sont want to be buying a head
post #10 of 32 (permalink) Old 01-15-2014, 04:51 PM Thread Starter
Well, I checked it out, and it still made the sound with the MCCT's backed out (with some clacking going on from the lack of pressure.) However, an older video I took one can hear the squeaking sound. So it's run for about 1000 miles pretty well, since I bought it.
