Engine just stops running on its own - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-22-2007, 07:07 AM Thread Starter
'95 ---Starting out, the bike runs fine. Two miles down the road, engine just stops while traveling. I thought I had a bad tank of gas. So, I ciphened it out and replaced with new from different station. Again going down the road, engine stopped while traveling. Any ideas? Yes, I checked all lead wires to plugs and seem to be in order. No, didnt accidentaly hit kill switch.
Last edited by jack smith; 06-22-2007 at 07:09 AM. Reason: Misspelling and punctuation
jack smith is offline
post #2 of 10 (permalink) Old 06-22-2007, 07:27 AM
My first guess would be the carb floats may be sticking.
Have ya Seafoamed it at all?
Second guess would be plugged vent lines.
Does the bike start back up easily after ya let it sit for a couple minutes or so?
post #3 of 10 (permalink) Old 06-22-2007, 10:20 AM
Loran in Npvl IL's Avatar
double check the battery cables to make sure they are tight
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #4 of 10 (permalink) Old 06-22-2007, 10:32 AM
SEAFOAM! Put some in the tank and let it idle for awhile. Then let it sit overnight and problem should be gone! That stuff is amazing!
Tyger is offline
post #5 of 10 (permalink) Old 06-22-2007, 10:37 AM
Check the vacuum line going to the fuel petcock. Two miles is about how far mine will travel on the fuel in the bowls and lines.
wwmkwood is offline
post #6 of 10 (permalink) Old 06-22-2007, 08:31 PM Thread Starter
yes to both hyper and thanks
post #7 of 10 (permalink) Old 06-22-2007, 08:33 PM Thread Starter
Thank you all. I will check all that you have mentioned.
post #8 of 10 (permalink) Old 06-22-2007, 11:09 PM
Rubline's Avatar
Does it shut down like there is an electrical problem, or does it sound like its starving for fuel and then stall.
Rubline is offline
post #9 of 10 (permalink) Old 06-22-2007, 11:30 PM
HAWK
Ccspinner's Avatar
The ignition has been known to have dirty issues at times.
If it just stops and not stumbles might be that.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 10 (permalink) Old 06-24-2007, 02:52 AM
Is the engine just shutting off/dying or are you actually losing all electrical power?
Does it start right back up?
I would wiggle the key/ignition and the ignition wiring (if you can get to it)while it's warming up ansd see if you have a bad ignition switch.
racohoon is offline
