remove exhaust for crash guard? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-29-2013, 10:08 PM Thread Starter
Chasin' the blacktop
Spencer1's Avatar
Just bought an E-Bay engine guard. picture in link below.
Do I need to remove the front exhaust pipe and if so do I need to order a new exhaust gasket?
http://www.ebay.com/itm/Engine-Crash...p2047675.l2557
North Georgia
Spencer1 is offline
post #2 of 8 (permalink) Old 12-29-2013, 10:32 PM
when sharky and i put mine on i reused my gasket. i have issues with my exhaust manifolds and planning to rplace the manifolds with all new studs/bolts when they get back from being powder coated.
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #3 of 8 (permalink) Old 12-29-2013, 10:41 PM Thread Starter
Spencer1's Avatar
Thanks Goofin, Just hope my exhaust bolts aren't sticky and break.
North Georgia
Spencer1 is offline
post #4 of 8 (permalink) Old 12-29-2013, 11:02 PM
spray them for a few days before trying. i have bent and stripped studs on mine. dont know why but no leaks
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #5 of 8 (permalink) Old 12-29-2013, 11:11 PM Thread Starter
Spencer1's Avatar
Since the bike is down for repainting I'll give 'er a shot of lube tonight. I'm trying to get little jobs like this done before I remount the tins.
North Georgia
Spencer1 is offline
post #6 of 8 (permalink) Old 12-30-2013, 12:23 AM
Be VERY careful with those exhaust studs. Over the years rust causes them and the nuts to weld themselves together. If you have to, it is way better to cut the nuts off and replace them rather than break them off in the manifold. And far worse is breaking the manifold studs off in the heads. I put anti-seize stuff on all the nuts and studs several years ago when I had the exhaust system off, and loosen and retighten them about once a year.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 8 (permalink) Old 12-30-2013, 12:38 AM Thread Starter
Spencer1's Avatar
I'll use penetrating oil for a few days and maybe take a torch to the nuts before trying to remove them. Also,,, how do you cut on of those nuts off??? They're acorn nuts so I can't crack them can I?
North Georgia
Spencer1 is offline
post #8 of 8 (permalink) Old 12-30-2013, 02:55 PM
you should be able to cut them with a dremel if need be
the ones on my 86 had no problem coming off nor did the ones on the 96 motor i have now
