Shout out to Piro!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-17-2007, 09:34 PM Thread Starter
Crobins365's Avatar
Smile Shout out to Piro!!
I've been living in fear of trying to install the front bevel gear case, made worse when Piro said he had spent three hours and much blood, and he still didn't have it in. Then all of a sudden, he's riding! Quick PM, he says, "loosen the bolts and drop the swingarm," and I'll be darned if I didn't have the case in within about 15 minutes. THANK YOU!!
DMAG, I couldn't find anything in the Verses, but maybe that could be posted as a "helpful, insurance-friendly hint" on how to reinstall that thing?
C
Crobins365 is offline
post #2 of 5 (permalink) Old 06-17-2007, 09:53 PM
93VN750's Avatar
Cindy -
There are those that get the front bevel back in without pulling the rear wheel.
I tried for 5 minutes, saw how easy it would be if I pulled the rear wheel. 30 minutes later, front bevel and rear wheel back on. No frustration.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 5 (permalink) Old 06-17-2007, 10:20 PM
On this subject mine is leaking oil out the bottom. Is that usually a sign it needs to be replaced or just the gasket? Its a small amount. Other than checking the oil am I risking a major malfunction while riding down the road?
ryn6609 is offline
post #4 of 5 (permalink) Old 06-17-2007, 11:20 PM
Glad you got it back together and, glad I could be of help.
piromedicx is offline
post #5 of 5 (permalink) Old 06-18-2007, 07:08 AM Thread Starter
Crobins365's Avatar
You're leaking oil out of the front bevel gear case? Can you pinpoint the spot? Probably just need to replace the gasket (which, of course, means pulling the case), but you can do that with the bike in the frame. Check where the leak is and holler back to the Forum - someone here can tell you for sure what's going on.
C
