Front cylinder ACCT install ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-17-2007, 08:10 PM Thread Starter
Likely a dumb question but I will ask anyway. If one were to wanna remove the front cylinder ACCT for a spring overhaul, what would it take to get the 'rigid' oil line bracket out of the way of the inboard stud?
bonzer is offline
post #2 of 5 (permalink) Old 06-17-2007, 08:30 PM
93VN750's Avatar
Use a right angle needle nose and carefully bend the tab up off the stud.
Don't see any need to resecure it when ACCT replacement is done as there is plenty of other securment for that line.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 5 (permalink) Old 06-17-2007, 09:35 PM Thread Starter
Why didnt I think of that, I started looking around to figure what I needed to loosen it enough and got very depressed....
bonzer is offline
post #4 of 5 (permalink) Old 06-17-2007, 09:35 PM
Crobins365's Avatar
Jon
What Jon said - I've left mine bent, and the bike's none the worse for wear.
C
Crobins365 is offline
post #5 of 5 (permalink) Old 06-18-2007, 12:56 AM
Mines left bent off the stud too.
