Air Filter Housing Cracked - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-17-2007, 09:22 AM Thread Starter
Prior to me owning the bike, someone over-tightened a couple of the bolts that secure the air filter element assembly to the air filter housing. This cracked/split open the plastic stem that holds the nut which the bolt goes into.
Has anyone had success in repairing/welding the plastic air filter housing?
I'd like to know what works so I don't damage it further with the wrong compound.
Victor is offline
post #2 of 5 (permalink) Old 06-17-2007, 10:13 AM
I stumbled onto a link at someones private vn750 site awhile back that had the same problem. He installed a small automotive hose clamp around the plastic crack to pinch it back together again enough to hold the nut from spinning. Easy, cheap fix IMO.
bonzer is offline
post #3 of 5 (permalink) Old 06-17-2007, 05:28 PM
I remember seeing that fix before. Should work just fine.
post #4 of 5 (permalink) Old 07-01-2007, 06:53 AM Thread Starter
Thanks
The hose clamp idea seems to work well. Thanks for the advice.
Victor is offline
post #5 of 5 (permalink) Old 07-02-2007, 06:41 PM
Rubline's Avatar
Woudnt super glue work?
Rubline is offline
