Coolant smell? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-15-2007, 09:28 PM Thread Starter
Coolant smell?
Yetsreday and today I noticed a strong coolant smell when bike is on. I checked and didnt see any areas leaking. Bike stays in garage so I think I would notice a leak on the ground. Coolant level sits in the middle between high and low on the overflow tank. Anyone experienced this before and did it lead to something bad?
ryn6609 is offline
post #2 of 10 (permalink) Old 06-16-2007, 07:42 AM
Crobins365's Avatar
I'd check all the hoses first and make sure you don't have a slight leak coming from somewhere. Also, pull the right front cover off the bike and check that your radiator cap is on tightly and that those hoses are snug. Check the coolant hoses going into your cylinders. And then check around the overflow bottle to make sure all hoses are cinched down tightly. If you have an internal leak, you shouldn't smell anything (I don't think), so shoot for the obvious first. Hopefully it's just a slightly loose pipe band.
C
Crobins365 is offline
post #3 of 10 (permalink) Old 06-16-2007, 10:12 AM
Search Goddess
Dianna's Avatar
Cindy is right on with this.
Check the hoses especially the one upper left (facing the bike) and make sure they are snug. If you have gone through some temperature changes lately the hose can develop what is known as a "cold water leak" (different materials expand and contract differently)
What you may be smelling is a fine misting from the hose, just enough to get the whiff of coolant smell.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 10 (permalink) Old 02-25-2008, 01:17 PM
i have been haveing the same problem i will do the same and let ya know thanks for the info all.
elubas is offline
post #5 of 10 (permalink) Old 02-25-2008, 08:33 PM
93VN750's Avatar
Also check hoses and the o-rings on the pipes that go into the top of each head.
Check overflow bottle too.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 10 (permalink) Old 02-26-2008, 05:59 AM
Chucklehead
dragon159's Avatar
An internal coolant leak shows up by white smoke out the exhaust or a chocolate milk like residue on the oil cap, and if you can smell it, it has to be external.
dragon159 is offline
post #7 of 10 (permalink) Old 02-28-2008, 03:18 PM
Most likely the coolant leak, if there is one, is at the lower end of the pipe Dianna's talking about; right side as you sit on the bike, front cylinder. It could also be the hose at the upper end of that same pipe; check the corresponding pipe on the other side of the rear cylinder, too.
I'd bet, if you look closely, when you smell the coolant you'll see some moisture down in the bottom of the valley between the cylinders... Been there before, a couple times or three.
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #8 of 10 (permalink) Old 02-28-2008, 09:00 PM
Sky Rider's Avatar
You could also be leaking from the long hose that meets a metal fitting aft of the air box. It it's there, it can drip onto the rear cylinder and you can get the smell. The hose runs aft along the to[ of the air box and then makes a 90 degree turn to the left as you look at it from the rear of the bike about where the rear of the gas tank sits.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 10 (permalink) Old 02-29-2008, 04:48 PM
Jim
Been there too. Had a very slight coolant smell. Finally noticed a small amount of fluid around the rear cylinder pipe. It got fixed when the shop did my stator change. No more coolant smell
post #10 of 10 (permalink) Old 03-03-2008, 08:59 AM
Went and took the radiator off the other day found the leak on the upper hose, very small leak hard to find reinstalled the hose sinched dowen on the hose clamp problem solved. thanks all
elubas is offline
