rebuild trouble shooting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-13-2013, 12:48 AM Thread Starter
So I did a 100% rebuild and, against me better judgement, also did an ear shave. The reason I say that is because I introduced an additional variable to my tuning.
Question: I originally assumed my studdering while riding was due to air fuel ratio and carb adjustment . Idle is fine and very pleased but while test riding is not 100% or even 50%, I've adjusted a fair amount and the ride is still sluggish and shakey. It starts great (even in 40 degrees) and it'll drive but its NOT RIGHT. Any ideas? Is it possible I f'ed up the timing. I followed the.procedure to a T.
Suggestions? I've come so far
tgell001 is offline
post #2 of 8 (permalink) Old 12-13-2013, 11:20 AM
About what speed and rpm does it lay down? Describe it a bit more.
For starters, where is the carb vent line?
Have you read the plugs at all?
post #3 of 8 (permalink) Old 12-13-2013, 01:26 PM
Is it running poor thru all rpms?
post #4 of 8 (permalink) Old 12-13-2013, 07:44 PM
Did you rejet the carbs, and if so, to what? What filters are you using? Do you have an aftermarket exhaust or modified stock exhaust? If you increase the airflow too much, it will be beyond the tuneable range of the carburetors, but you generally have to run open pipes to get that far off.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 8 (permalink) Old 12-14-2013, 09:35 AM
Wow, I can't believe I read that on this site. Jerry, reality can be a hard sell here. I personally do not care enough, but I am right behind you on this.
wmsonta is offline
post #6 of 8 (permalink) Old 12-16-2013, 07:33 PM Thread Starter
I rejetted it to the jets listed on the toutorial on this site. I'm running the K&N cone filters. Stock exhaust with a leak somewhere in the goats belly (get to that after i fix this haha)
Jets
1 Keihin (Sudco) Needle Shims Item# 009-396 $7.95
2 Keihin PN: 99101-393 Main Jet Size: 142 $13.90
2 Keihin PN: N424-22 Pilot/Slow Jet Size: 42 $13.90
Total $35.75
I haven't read the plugs yet cuz its been freezing and i haven't been on this a whole lot.
Sluggished at all RPMs, guess i'd say it rev's slowly too with the clutch in. will rev up but its not as fast as it did before the rebuild nor what i'd expect.
Hmm carb vent line? I dont know off the top of my head, i'll check that tomorrow.
tgell001 is offline
post #7 of 8 (permalink) Old 12-16-2013, 07:58 PM
Jets
Total $35.75
Could it be your Fuel-Flow thru the Petcck ?
...just a thought
post #8 of 8 (permalink) Old 12-16-2013, 08:30 PM
Jets
Total $35.75
If you did all of that with stock exhaust, you are probably way too rich. When you open the throttle does it hesitate or shortly thereafter?
wmsonta is offline
