Where do you marble? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 06-14-2007, 03:20 PM Thread Starter
Greetings everyone,
I picked up a loaded 02 vn750 last weekend with 3900 orig. miles on it and have been hovering around your site this week, very good info indeed.
I have already (successfully) Grambo'd which I believe spooked the owner into selling in the first place? Long story short, I also have the preverbial 'paint can rattle' under the seat and understand it is common to marble the air-valve? Question, can you marble in the box itself or do you need to stuff them at the valve cover ends. I'm considering coastering but want to get through inspection before I rip it out.
bonzer is offline
post #2 of 13 (permalink) Old 06-14-2007, 03:41 PM
93VN750's Avatar
Take the hoses form the reed valave off at the valve body and put a marble in each one. Re-attach to valve body to keep look of intact system.
Remove small vacuum hose (not fuel line) from right carb and plug open port with rubber vacuum stopper.
Pull vacuum hose back into hidden area under seat to maintain look of intact system.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 13 (permalink) Old 06-14-2007, 03:51 PM Thread Starter
Excellent, Thanks Jon....
Will I need to adjust the carb mixture(s) afterwards? or what symptoms should I be aware of that will indicate the necessity to do so.
bonzer is offline
post #4 of 13 (permalink) Old 06-14-2007, 04:12 PM
93VN750's Avatar
I wouldn't touch anything unless you get excessive muffler popping.
Then richen up the mixture screws (clockwise) a little at a time until popping is minimized.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #5 of 13 (permalink) Old 06-14-2007, 04:23 PM
The popping you speak of, is that when you eas off the throttle? My bike does that, but I havn't bothered with anything yet.
post #6 of 13 (permalink) Old 06-14-2007, 04:31 PM Thread Starter
Thanks again Jon, I will grab some marbles over the weekend and post my results.
bonzer is offline
post #7 of 13 (permalink) Old 06-14-2007, 04:37 PM
93VN750's Avatar
The "coastering" or reed valve disabling this thread talks about is the best way to stop the muffler popping on deceleration.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #8 of 13 (permalink) Old 06-14-2007, 09:00 PM
Geek
rnewell's Avatar
Jon
Isn't it counter clockwise to make it richer ?
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #9 of 13 (permalink) Old 06-15-2007, 08:04 AM
Bonzer, when I did mine I used copper tubing caps for 5/8 od tubing and they worked great. Pulled off hoses from reed valves and the caps snapped right over the hose nipple on the reed valve. Then I replaced the hose back over the capped connection. Can't tell anything was done. Stopped the majority of backfiring on deceleration. Still do get an occasional pop, but I can live with that. Did not adjust the idle mixture screws as of yet. That would probably eliminate it altogether. Good Luck.
ratuck is offline
post #10 of 13 (permalink) Old 06-15-2007, 09:11 AM
BMan23777's Avatar
Yes counter clockwise richens the mixture and clockwise leans the mixture out.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
