Thermostat nipple. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-08-2013, 12:26 AM Thread Starter
Big Nick's Avatar
Thermostat nipple.
So I checked the thermostat and the nipple in the side is missing.
The question is,should it be there in this application,and if not will it cause overheating?
Any takers.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 4 (permalink) Old 11-08-2013, 02:51 AM
What are you calling a nipple? I just looked through the parts diagram and don't see what could be missing with out causing a huge leak, other than the gauge sending unit located on the top of the T-Stat Housing.
I think in this case a picture is worth a thousand words.
post #3 of 4 (permalink) Old 11-08-2013, 08:15 AM Thread Starter
Big Nick's Avatar
Thermostat element.
Sorry, I was talking about the thermostat itself not the housing.
The sandwich plate on the thermostat element,has a hole in it with a primitive valve,I've always assumed it was for steam or air to move around the main water tap"thermostat". So if this bead or nipple is missing it allows a small flow of fluid to continually bypass. At a guess over a distance, this could cause temperature to rise. I found one like this in a spare bike I've been fixing. Just wondering what your opinion on it, would be?
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #4 of 4 (permalink) Old 11-08-2013, 09:43 AM
I don't think it will matter. I know some will drill a small hole, but on larger cooling systems.
