Camshaft re-fitting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-06-2013, 05:22 PM Thread Starter
Camshaft re-fitting
Rebuilding the top end of an '86 750cc. Have had to relap valves but not by too much, no seat cutting involved. Come to fit the cams to the front cylinder and notice that when tightening down, particularly on the inlet side, the cam is tensioning the valves, and when tightened down is almost solid in its bearings. surely there should be some tightening when tensioning the lash adjusters, but this much?
Any ideas?
Dave Richards is offline
post #2 of 6 (permalink) Old 11-06-2013, 05:56 PM
Didn't mix the cams up? It's happened before. I've read that cam assemblies are select fit, so mixing them up could cause binding.
If the lobe is up on the rocker, it would be normal to see the valve opening.
Might need to try it with the rockers removed to make sure the cam journals aren't binding.
post #3 of 6 (permalink) Old 11-06-2013, 07:37 PM
Yeah, it was Newrider9984 who taught us that error. If more info is needed, Contact NewRider9984.
post #4 of 6 (permalink) Old 11-06-2013, 08:34 PM
Shouldn't bind at all if you set the piston at tdc call me tommorow and I can walk you thru it my number is in my sig line
post #5 of 6 (permalink) Old 11-06-2013, 09:27 PM
Thank you NewRider9984 !
post #6 of 6 (permalink) Old 11-07-2013, 02:46 PM Thread Starter
I appears that I have sorted it. 2 of the lash adjusters that appeared to be solid and not full of air were somehow 'overpumped'. when I bled them all they just gave enough to free the camshafts when they were tightened down. A good lesson to learn.......always bleed them all
