HELP - Rotor Puller? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-01-2007, 04:55 PM Thread Starter
Crobins365's Avatar
Thumbs down HELP - Rotor Puller?
Uncle! I am completely lost as to what tool I should be using to pull the alternator rotor. Baffled the guys at NAPA (tho' that's pretty easy), and then baffled my mechanic. He let me borrow what was essentially a flywheel puller, but the clamps wouldn't fit behind the rotor (not enough room).
Can somebody help? Am I looking for what would essentially be a flywheel puller, or am I missing something altogether?
C
Crobins365 is offline
post #2 of 10 (permalink) Old 06-01-2007, 08:02 PM
I thought someone posted a pic of the rotor puller here, but darned if I can find it.
I'm pretty sure it looked something like the one below.
The large nut looking piece screws into the rotor, then the bolt is turned down into the nut, bottoming out and forcing the rotor up and off the tapered shaft.
post #3 of 10 (permalink) Old 06-01-2007, 08:39 PM
james brill's Avatar
puller or holder, shows a holder in the manuel
james brill is offline
post #4 of 10 (permalink) Old 06-01-2007, 08:40 PM
93VN750's Avatar
Cindy -
I think you need one of these http://www.motionpro.com/motorcycle/partno/08-0116/.
Yes?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 10 (permalink) Old 06-01-2007, 08:51 PM
Cindy, the one that Jon posted is exactly what you need....wow I wish I knew about that place when I bought mine for twice the price on ebay
its only an 18mm bolt (can't remember the pitch)
TrashLord is offline
post #6 of 10 (permalink) Old 06-01-2007, 08:51 PM
That's the one !!!
Guess I was a little mistaken on how I though it came off.
post #7 of 10 (permalink) Old 06-01-2007, 09:31 PM
93VN750's Avatar
Originally Posted by hyperbuzzin View Post
That's the one !!!
We're all in this thing together.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #8 of 10 (permalink) Old 06-01-2007, 10:59 PM Thread Starter
Crobins365's Avatar
18mm or 16mm? Someone on the Yahoo group said, "16mm x 1.5mm (pitch?)". I suppose I can use my calipers and measure the ID.
So, that's really it? Get a bolt that fits the ID of the rotor, screw it in, and as it screws in, the rotor comes off the shaft? Dag, I'm making this harder than it has to be.
Thanks, folks, I'll see what I can find in the a.m. and post progress from there!
Oh, and Hyper, i think yours does exactly the same thing - nut screws into the ID of the rotor; then torque down the screw and it should pull the rotor off the shaft...I think? Anyway, the folks on the Yahoo group found this item on eBay (190117802147), which looks like the one Jon noted; and then there was a discussion about something that sounded like what Hyper posted. I just "bought it now" 'cause I can see myself spending all weekend looking for a 18mm 1.5mm right-hand threaded bolt.
THANKS, folks!
C
post #9 of 10 (permalink) Old 06-02-2007, 08:04 AM
You won't find a bolt that size with those treads, believe me, I looked. But that is exactly how it works. I used an impact wrench with my puller but the penny between the rotor and balancer gear should work.
wwmkwood is offline
post #10 of 10 (permalink) Old 06-02-2007, 08:31 AM Thread Starter
Crobins365's Avatar
Thanks, then I won't even think about going back to Napa today...ha ha. They'll be happy not to see me.
The one I bought on eBay is 18 x 1.5, so hopefully that's it. I was waiting to place an order with Ayers until I could pull the rotor and see what the dampers on the balancer looked like, but maybe I'll just go ahead and order them (if they're affordable).
C
