upswept exhaust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 11-03-2013, 09:58 PM Thread Starter
upswept exhaust
Does anyone have one or a mockup. I want something a little old school. i still have the stock exhaust and was thinking of doing duells or could chop the one i have and do them both on the same side. any ideas fellas.
TheEDGE is offline
post #2 of 17 (permalink) Old 11-04-2013, 12:50 AM
Dr. Vulcanstein
jadabull's Avatar
Something like this?
http://www.youtube.com/watch?v=3ROUe-fWgYE. I'm thinking of doing something similar, basically just making my end tips a little different. These don't have any baffles in them by the way.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 17 (permalink) Old 11-04-2013, 02:14 AM Thread Starter
Yea just like that. you awsome brother thanks for that
TheEDGE is offline
post #4 of 17 (permalink) Old 11-04-2013, 02:55 AM
Dr. Vulcanstein
jadabull's Avatar
No probs. I havnt mocked mine up yet, but given lots of thought. You can use your stock headers, get rid of the goats belly and the muffs. Should be able to go to a Napa, or local muffler shop to get the tubing, wish I had a tube bender. If using stock headers get two 90 degree elbows, 3 straight pipes, whatever size you decide. You'll probably have to go to a muffler shop to get the upswept elbows custom made, (unless you have a tube bender with proper dyes) I'm guessing his are around 80 degrees. Personally I would go with like 75 degrees (or make the parallel straight pipe a lil longer) if you plan on ever having a passenger to keep the back of their ham from cooking.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 17 (permalink) Old 11-04-2013, 03:06 AM
Dr. Vulcanstein
jadabull's Avatar
Also, you shouldn't have to worry about re-jetting. These type of pipes are plenty long and create good backpressure. If you do need to equalize the pressure, it would be from the left side pipe as its the shorter of the two. I've heard of people drilling a hole through the pipe near the tip, and inserting an eye bolt. Tack weld in place ,grind down to clean it up, and paint, or whatever finish you like. The ring from the eye should give just enough extra back pressure to equalize, if in fact you even need two.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 17 (permalink) Old 11-04-2013, 12:20 PM Thread Starter
I already have a set of macs on so ma just cut and fit. also already rejeted for the ear shave so sould have no problems there
TheEDGE is offline
post #7 of 17 (permalink) Old 11-04-2013, 01:15 PM
Well brother let me know when you mess it up so I can fix it
post #8 of 17 (permalink) Old 11-04-2013, 01:27 PM
If you run a tube under the bike it will give you another 5-6".and if still not equal can still run it a little longer.Wolfie gave me a good idea but i promised him i'd keep it under wraps until it's finished.by the way Wolfie,do you have any pics of your fishtails mounted up?
post #9 of 17 (permalink) Old 11-04-2013, 04:46 PM
what?? you haven't heard them yet....lol
Originally they were unbaffled and I had the pleaseure of riding behind Wolfie in the highway heading towards PA to meet up with others......my ears are still ringing...
You talked about upswept pipes at Strange days.....you gonna run it real rich put plugs on the ends to shoot flames??
post #10 of 17 (permalink) Old 11-04-2013, 05:45 PM
Mine aren't too quiet either.thought about pulling the baffles but thought against it.planning something different for the 86.Wolfie gave me an idea but have to see if it is workable.gonna get another exhaust manifold and that is all i got to say about that.lol.when it's done you'll probably hear me in Jersey .lol.been eating a lot of beans lately.just gonna mount a BBQ grille ignitior right behind the seat
