So where is my coolant going???? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-31-2007, 12:43 PM Thread Starter
93VN750's Avatar
Inital thought was head gasket. Compression test yield a healthy 160 in each cylinder. Next thought was mechanical seal behind water pump impeller, drained oil last night and it looks fine, nothing but oil. Plugs look normal, not like burning coolant in with the gas/air mix.
No external leaks that I can see, nothing drips (or smells) while ride, no accumulation under the bike when it sits.
Yet, used an entire overflow bottle of coolant going back and forth to work, 75 miles!
Developing a good Nancy Drew Mystery here!
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 6 (permalink) Old 05-31-2007, 12:56 PM
Crobins365's Avatar
Did you pull the right crankcase cover to double-check the impeller and mechanical seal? The only other thing I can think is that you've overfilled your coolant (reservoir level should be measured when the bike is hot) and that you've just expelled the excess through the drain hose while riding.
Perhaps the Hardly Boys can help out Nancy??
C
Crobins365 is offline
post #3 of 6 (permalink) Old 05-31-2007, 01:00 PM Thread Starter
93VN750's Avatar
Cindy -
Wouldn't the excess going out the overflow tube generate the nomal A/F stink? Because I never smell a drop, even sitting at a light.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #4 of 6 (permalink) Old 05-31-2007, 01:15 PM
Crobins365's Avatar
Originally Posted by 93VN750 View Post
Cindy -
Jon
It should, although the last time I used Dexcool, it didn't smell much at all. What kinda coolant you using?
C
post #5 of 6 (permalink) Old 05-31-2007, 01:38 PM
Hmm, with Gremlins afoot here, maybe Scooby Doo and friends would be better detectives for this mystery?! LOL
How sure are you that the coolant in the rad was full?
Maybe it was low and then filled up with what was in the overflow bottle?
Or have you been needing to fill the bottle often?
Have you had a chance to ride with someone following ya, to see if they notice any coolant smell?
I can't say I've heard of Gremlins being too much into drinking that much coolant. But it's gotta be going somewhere !!
Scooby Doo..... Where are you ??!!
post #6 of 6 (permalink) Old 05-31-2007, 05:23 PM
Rider on the Storm
EasyRector's Avatar
My coolant question... it doesn't seem to matter whether my coolant is low or filled to the brim -- the level looks the same! What's up with that?!
EZC
EasyRector is offline
