gasket sealant use or not - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-31-2013, 10:18 AM Thread Starter
emtdon's Avatar
sorry if this is a stupid question, but i was wondering if i should sealant on the engine cover and front bevel gear gaskets. if so what kind is recommended. they are factory gaskets.
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 11 (permalink) Old 10-31-2013, 10:29 AM
Not a stupid question.
As I know it, Sealant generally not needed when good gaskets are used.
With Gaskets being expensive, many make their own out of purchased (rolled) Gasket Material , Cereal Box's or Manilla File folders (trace outline of cover ...etc.).
hope this helps
post #3 of 11 (permalink) Old 10-31-2013, 11:10 AM
I use the high temp black stuff on any gasket I don't plan on getting back into anytime soon. It's a real pitta to clean off. Just be carefully on the amount you use as you don't want excess squeezing into the engine where it can cause problems.
I usually apply a thin coat with my finger to spread it out.
But, good gaskets & a good clean non knocked surface shouldn't require it.
post #4 of 11 (permalink) Old 10-31-2013, 12:45 PM Thread Starter
emtdon's Avatar
thanks i didn't think so with the factory type gasket. i thought maybe a little just to hold in place with the help of the alignment pins.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 11 (permalink) Old 10-31-2013, 01:01 PM
Absolutely, a mechanics helper.
post #6 of 11 (permalink) Old 10-31-2013, 01:11 PM
I use bearing grease for that. Just a dab will hold the gasket in place while you line everything up.
post #7 of 11 (permalink) Old 11-01-2013, 07:19 PM
I normally don't use any kind of sealant on the Vulcan, but I made an exception to that for the bevel drive cover. It is difficult to install that cover, because you have to install it against spring pressure from the damper, and line up the driveshaft splines at the same time. The first time I tried to install it, I destroyed a brand new gasket. I got another new gasket, and used Permatex gas resistant black RTV sealant to glue it to the engine. I let it sit overnight and cure. This time the cover went on fine. This sealant is not like the usual silicone RTV stuff. It dries harder, and does not feel at all like cured silicone. I don't plan on ever removing this cover again, so I wasn't too concerned about how hard the stuff would be to get off.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 11 (permalink) Old 11-02-2013, 11:20 PM
I just jerk off into a shot glass then rub it on the mating surfaces ...sticks great....
post #9 of 11 (permalink) Old 11-02-2013, 11:27 PM
Dr. Vulcanstein
jadabull's Avatar
Is the Molly 60% required for this procedure?
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #10 of 11 (permalink) Old 11-02-2013, 11:29 PM
...yeah...redheaded Molly....lol
