vn750 rpm guage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-29-2013, 12:50 AM Thread Starter
vn750 rpm guage
guage jumps around from 1000 to 3000 rpms at low rpm or high rpm it doesnt matter what rpm its turning. anyone have any idea what it could be?
candyman4092 is offline
post #2 of 12 (permalink) Old 10-29-2013, 12:53 AM
Dr. Vulcanstein
jadabull's Avatar
Could be a few different things, first check to make sure the rubber boot between the carbs and intake are tight. You can spray a little carbs cleaner in there while the bike is idling, if it receive up you have a leak.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 12 (permalink) Old 10-29-2013, 01:06 AM Thread Starter
the engine doesnt idle up and down the tach is just flipping around
post #4 of 12 (permalink) Old 10-29-2013, 01:09 AM
idk.... since it is electrical, I suggest check your grounds/electrical connectors.
hope this helps
post #5 of 12 (permalink) Old 10-29-2013, 01:15 AM Thread Starter
thanks ill try that
post #6 of 12 (permalink) Old 10-29-2013, 02:58 AM
Check the connectors behind the left neck covers... Iirc, the red one is for the gauges, it could be lose or corroded. If the connectors ate fine, then I would look at the tachometer itself
post #7 of 12 (permalink) Old 10-29-2013, 09:47 AM
And check your battery terminals, they vibrate loose sometimes and that will do the same thing. Could be that easy.
post #8 of 12 (permalink) Old 10-29-2013, 10:47 AM
the Tach is electrical and runs off the front ignition coil signal.
Check your battery connections and grounds... frame to engine ground... and frame to battery ground straps.
Also check the front coil connections ...you should have 12V(battery voltage) on the coil primary and signal from the ignition to fire the coils.
also look at the connector under the cover for the tach signal like Slim said
post #9 of 12 (permalink) Old 11-04-2013, 06:23 AM
2000 VN 750 Senior Member
Originally Posted by gamefacebookdevelop View Post
At JC Whitney, we offer the best selection of Kawasaki VN750A Vulcan 750 Gauges & Gauge Brackets parts and accessories. We offer an industry leading 30-day Guarantee so that you can shop with confidence! Narrow your selection below by providing the year of your vehicle for a custom list of Kawasaki VN750A Vulcan 750 Gauges & Gauge Brackets products.
This sure seems like you did a cut and paste from the JCWhitney website or you are actually an employee of the customer service/sales department there. Your one and only other posting represents you as a VN750 owner. This is all a bit questionable and confusing. Most new members do not introduce themselves in such a manner. Please clarify your true status.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #10 of 12 (permalink) Old 11-04-2013, 07:08 AM
Spammarino
Tags
vn 750 , vulcan 750 , vulcun
