Compression Test Results... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 05-28-2007, 05:23 PM Thread Starter
93VN750's Avatar
I got 160 on both cylinders on about the exact amount of engine revolutions.
So, is it possible that the head gaskets are fine?
Is it possible that the compression test will not detect a leak between the coolant system and crankcase?
Is it possible that the impeller seal on the water pump is bad casuing my oil/antifreeze mix?
Thoughts, comments, ideas, suggestions?
Thanks,
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
