Sump full of petrol/oil. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-23-2013, 09:09 PM Thread Starter
Big Nick's Avatar
As my igniter blew pre any start up, on my project VN, I decided to paint the frame and wheels,and do a good detail. Drained the sump, pre engine removal, and found a lot of fuel in the oil! Seems the product of mixin up vacum lines with fuel lines. My mistake and probably the cause. Carbs have since been cleaned and checked all good. My question is, If the oil pump has been washed clean of oil? Would there be an easy way to prime it,or would it self prime?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 5 (permalink) Old 10-23-2013, 09:44 PM
After you fill her up pull your spark plug wires off the plugs and turn the engine over til the oil light goes out. You should be fine, at least I was when I did it this way.
post #3 of 5 (permalink) Old 10-24-2013, 11:48 PM Thread Starter
Big Nick's Avatar
Thanks for the tip.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #4 of 5 (permalink) Old 02-21-2014, 12:21 AM Thread Starter
Big Nick's Avatar
Smile self primed.
Well it all worked out,new CDI, detail,flash oil filter and premium oil. Starts at the drop of a hat,revs clean and no smoke. Happy!
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #5 of 5 (permalink) Old 02-21-2014, 12:35 AM
Sweet.
