I'd say my riding season is over now... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 10-18-2013, 08:39 PM Thread Starter
OMEGA
Z Guy's Avatar
Has been around 30 degrees in the morning here for the last couple days. Today the bike was really struggling to turn over until it started. Got about a mile down the road before i heard a "slapping" sound. Then within another mile the bike started to vibrate harshly. With the clutch in, it wasn't noticeable through the frame (as noticeable at least). Pulled over to see at least a couple quarts worth of oil finish draining out of a place where there should not be a drain hole...
I haven't had a chance to look at it close yet, but does this sound like anything you guys have gone through before? should i start looking for motors, or is a rebuild usually possible?
Thanks Click image for larger version
Z Guy is offline
post #2 of 18 (permalink) Old 10-18-2013, 08:42 PM
Okiebezer's Avatar
That doesn't look promising. Would need to see snapshot of where the new drain hole is...
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #3 of 18 (permalink) Old 10-18-2013, 09:15 PM
The location makes me think a balancer gear let go and busted the case. SWAG
post #4 of 18 (permalink) Old 10-18-2013, 09:46 PM
Chasin' the blacktop
Spencer1's Avatar
Yea, Someone on this site had their balencer tear through the case about 6 months ago and your pict looks a lot like their pict.
North Georgia
Spencer1 is offline
post #5 of 18 (permalink) Old 10-20-2013, 08:28 PM Thread Starter
OMEGA
Z Guy's Avatar
Yah looks like the balancer I bet. What would you guess the damage is, and beat option to repair/replace?
Z Guy is offline
post #6 of 18 (permalink) Old 10-20-2013, 08:37 PM
If you can do the labor yourself your looking at about 300 to 500 for parts
post #7 of 18 (permalink) Old 10-20-2013, 09:09 PM
Not if you shop Ebay for those parts. Should be quite a bit lower.
post #8 of 18 (permalink) Old 10-20-2013, 10:02 PM
Riding season is just starting here, and I have my carbs out and disassembled. Great.
Your picture and description look and sound like a broken engine case by the damper. Left front of the engine. if there is a hole in the case, you will need another engine, or at least another left engine case, but that requires a TOTAL engine teardown. If you really must have a Vulcan 750 (and I do understand the attraction) your best bet is a used engine, or just get another Vulcan in good condition, and keep the one you have as a parts bike. I found out with my Yamaha XT225 that a parts bike is a good thing to have.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 18 (permalink) Old 10-20-2013, 10:29 PM
Left engine case around 100 bucks
Stator cover 50 to 100 bucks
Dampers 40 bucks
Head gaskets 35 x 2
Base gaskets 8 x 2
Damper gear if needed 40 to 80
Oil and filter 30 bucks
Antifreeze 10 bucks
And that's if you just use gasket sealer for the rest
You do the math
If you get a used engine I would recommend replacing the dampers before you install the engine just for peace of mind
post #10 of 18 (permalink) Old 10-20-2013, 10:53 PM
Dampers 40 bucks
Head gaskets 35 x 2
Base gaskets 8 x 2
Antifreeze 10 bucks
You do the math
I agree. I would also do the Tuxedo Mod and a TPE stator at the same time, regardless if you decide to go with a second engine or not.
