Fergy can you send me pics of your dyna brackets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-16-2007, 05:50 PM Thread Starter
please lol i just ordered a set
Devilin is offline
post #2 of 10 (permalink) Old 05-17-2007, 04:23 PM
fergy's Avatar
Sorry Devilin, I just found this. I'll try to shoot some pics this evening and send them to you.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 10 (permalink) Old 05-17-2007, 06:35 PM Thread Starter
scootworks kit and no baffels
loud
Devilin is offline
post #4 of 10 (permalink) Old 05-21-2007, 02:29 PM Thread Starter
FERGY you forgot about me lol my dynas should be here any day now...... hehe
Devilin is offline
post #5 of 10 (permalink) Old 05-21-2007, 07:50 PM
Wished I would have known you need Dynas I would have let you have mine that I never got a chance to install for the shipping$$
Woody is offline
post #6 of 10 (permalink) Old 05-21-2007, 08:10 PM Thread Starter
what do you have instead
and where in waterloo i graduated from CF in 93
Devilin is offline
post #7 of 10 (permalink) Old 05-21-2007, 10:45 PM
Nothing left from my 750 but the Dynas, scootworks pipes and Clymers manual. I to am a CF alum, Class of "79" also did Southdale and Peet. Live on Ridgeway by Kittrell Elem school now.
Woody is offline
post #8 of 10 (permalink) Old 05-25-2007, 05:27 PM
fergy's Avatar
Dang it Devilin! I forgot all about you again. We've been having storms like crazy and add to that my job is hopping like mad these days with camp starting in a few days. I just get home exhausted and haven't left the couch for several evenings. I'll try to shoot some pics tonight if it's not dark when I get home.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 10 (permalink) Old 05-31-2007, 12:46 PM
fergy's Avatar
Finally had time to get the pics off the camera and upload them.
Here is the strap metal I used to make the mounts.
I had these already, but you can get them at home depot. They're pretty rigid. I stuck the muffler on with no gasket material, so I could measure. I put the front bolt and nut on through the first hole in the strap metal. Then I used a permanent marker to mark the strap where I needed to bend it to bring the muffler out away from the swing arm. I probably need to re-do the right one as it just barely clears the swingarm by maybe 1/16". I put the strap metal in my bench vice and using a gloved hand, was able to bend it just enough to make the "S" bend. (I should have bent it a little more than I did) Then I put it on the muffler loose, and attached it to the bike, made some more marks with the marker, took it back off and used my dremmel to cut the end off, and my bench grinder to round the end and smooth it. Then I used some of that stretch and stick silicone tape. It's non adhesive, but when stretched and run back over it's self, it bonds. I used it to wrap the header end and slipped the muffler on over it. I bought some heavy duty muffler clamps from autozone to squeeze the muffler flanged end down tight over the header pipe. (goats belly pipe to be more accurate!) I have no leaks and this silicone tape is good for temps over 500 degrees.
Here's the left bracket with muffler mounted.
Here's the right one.
Here's the left dyna installed.
I had just detailed the bike from one end to the other the day before these photos. I think "detailed the bike" in indian means "rain dance", cause it's rained nearly every day since, as you can see from the road grime and rain spots! Anyway, hope this helps explain how I did it.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #10 of 10 (permalink) Old 06-06-2007, 05:54 PM
fergy's Avatar
Hey Devilin, you ever get your dynas put on?
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
