stock mufflers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-12-2007, 08:19 PM Thread Starter
stock mufflers
OK i have removed the baffels from the stock mufflers and left the screens in them and left the goats belly on. slightly louder at idle moderatly louder at crusing speed slightly more than moderatly louder at full throttle. next step to try is to remove the goats belly. mayble i can get someone in the area to make some pipes cheaper than scootworks kit. hmmmmmm?????
Devilin is offline
post #2 of 10 (permalink) Old 05-12-2007, 10:53 PM
HAWK
Ccspinner's Avatar
You can make a set out of Flex pipe and hose calmps, I believe there is a write up in the Verses about this.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 10 (permalink) Old 05-14-2007, 09:50 AM
There is a write up on the website about the flexpipe.
There is also a follow up staying that it only lasted about three months.
The parts for scootworks woud be worth the money. I would also keep an eye on eBay. I was able to get a Cobra slipon for the price of the scootworks parts.
JamieB is offline
post #4 of 10 (permalink) Old 05-14-2007, 10:19 AM
fergy's Avatar
If you have a local muffler shop, ask them if they can build you an H pipe to the right dimensions. If they can and won't charge an arm and a leg, you can remove the goats belly and give it to them to use as a model. Just a thought.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 10 (permalink) Old 05-14-2007, 02:40 PM
I got my H pipe free from a member that went back to stock for trade in. It was custom made and the above idea would easily work. Any good fab shop should be able to make one fairly cheaply. Give the goats belly to them and don't push for time. Try a local shop that specializes in custom hot rod exhausts. Who knows once they get the pattern they(you) might be able to sell them either here or on ebay.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #6 of 10 (permalink) Old 05-14-2007, 05:22 PM
85 VN 700
curtis97322's Avatar
rctmtn,
With the H pipe - what's the sound difference? Louder? More thump thump? Are your pipes modified in any way other than the H pipe? I have an extra goats belly since I got lurch's old exhaust (mine was corroded) so could get a muffler shop or a buddy to knock out a H pipe on their time - just wanna know how different the sound is.
Any noticible power loss or gains?
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #7 of 10 (permalink) Old 05-14-2007, 09:22 PM Thread Starter
Not really worried about the H - pipe sincs what you lose is low end and our motors dont make max power till about 6500 or so. now im wondering how to get rid of the poping and the dead spot in the throttle..... any suggestions?? Ok when you customise exhaust you should rejet due to the engine running to lean or too rich???? and i cant find my air/fuel adjustment screws......
Devilin is offline
post #8 of 10 (permalink) Old 05-14-2007, 10:08 PM
Somebodies got pics as Iv'e seen them on here before. They are on the side of the carbs, about 3/16" in diameter. They are lead caps just abouve the float bowls. Take a punch and carefully pop a hole in them and pry them off. I mad a homeade screwdriver out of coathanger wire to adjust them as I didn't have a real good tiny long shanked one.I'm sure Diana or Fergy can set up a pic.
Woody is offline
post #9 of 10 (permalink) Old 05-14-2007, 10:59 PM
I didn't notice any power loss and the sound increased quite a bit(according to my M.I.L). I had already marbled my bike so I didn't do any thing to the carbs. No dead spots just less heat on the R&R. I didn't have to modify anything other than removing the goats belly and replacing it with the "H" pipe. I remember reading sometime ago the advantage to the H pipe is that you still get equalization without the backpressure. I used flat clamps1 1/2"wide to seal the pipe joints after a coat of RTV was applied to the inner pipe and slide the system togather. I wish I had taken pictures of the h before installation but I didn't think that far ahead. Your shop should be able to make an exact replacemnt from the goats belly.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
Jardine 2 into 2
Luggage rack
130 DB horns
rckmtn is offline
post #10 of 10 (permalink) Old 05-14-2007, 11:09 PM
HAWK
Ccspinner's Avatar
Left
Right
Here are the picts, Thanks Dianna
Chad Falstad "Hawk"
Vroc #17649
