dampers, where the penny goes? marks on balancer. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-27-2013, 12:30 PM Thread Starter
emtdon's Avatar
wondering if the parts that is marked is correct where and what things are. trying to make sure im right before continuing. and is that the bolt on the balancer that is counter clock wise?
Name:	gears where penny goes.jpg
ID:	10818 penny goes here
ID:	10826 marks that have to be lined up.
any other tips that will help. thanks
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 14 (permalink) Old 09-27-2013, 12:48 PM
The first pic is the rotor, for the stator, not the balance damper.
The penny pic looks right, just need the penny where it will stop the gears for the direction you are turning. The bolt on the balance gear has the left hand threads. I used tweezers or hemostats to hold the penny in place until I got tension on it, kept pinching my fingers without them.
You have the correct marks. But also make sure to align the mark on the balance shaft with the mark on the weight. Some years have a dot stamped between splines on the shaft, and some have a stripe of paint on the shaft spline.
Now, ... pay attention to the balance gear and balance weight positioning when they go together. They will fit together two ways, but only one is correct. The largest post on the weight, belongs in the smallest hole on the gear. I put it together backward the first time and when I started the engine it shook so bad I couldn't see the handgrips and it bounced across the floor on the center stand like it was in gear.
So to recap, there are three places to align. Shaft and weight (dot or paint), weight and gear (big post to smallest hole), line mark on gear with rear line mark on the rotor (as in your second pic).
Don't skip using blue Loctite on the balancer bolt, I used it on the rotor bolt too.
post #3 of 14 (permalink) Old 09-27-2013, 01:03 PM Thread Starter
emtdon's Avatar
thanks a million, that helps a lot. everything looks really clean inside. I'm assuming the black particles in the oil was from the stator because it was melted with plastic pieces flaking off of it. gonna do dampers anyway while I'm there.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #4 of 14 (permalink) Old 09-27-2013, 01:25 PM
You're welcome. That's the best plan, mine weren't bad either but it makes sense to replace them while you're right there. A few more bucks but only one more bolt, and the catastrophe avoided is huge.
Hope you got a TPE rewind for your stator.
I'm up here in Wood county, btw. There were a couple others on here from the state but they haven't posted much since joining.
post #5 of 14 (permalink) Old 09-27-2013, 01:50 PM Thread Starter
emtdon's Avatar
haven't ordered the stator but that's who I'm ordering from. 80$ is a lot better than 120$ especially since it is better. is that parkersburg?
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #6 of 14 (permalink) Old 09-27-2013, 02:58 PM
gibbo's Avatar
Remember the damper left hand thread bolt is also loctite sealed. I jammed an old sock in the gears, just seemed a bit kinder on the teeth. It was certainly an old sock afterwards.
One can never have too many alternative forms of transport.
gibbo is offline
post #7 of 14 (permalink) Old 09-27-2013, 04:30 PM Thread Starter
emtdon's Avatar
thanks for the info. when my wife gives me my allowance i will get the other parts and stator.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #8 of 14 (permalink) Old 09-27-2013, 04:34 PM
yea screw the penny use an old sock or rag
post #9 of 14 (permalink) Old 09-28-2013, 01:08 PM
Is one of this bolts left handed?
post #10 of 14 (permalink) Old 09-28-2013, 01:16 PM
yes in the third pic the brass colored bolt is left handed or reverse threaded
righty loosey lefty tighty
