Exhaust system gaskets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-10-2007, 11:50 AM Thread Starter
Joem's Avatar
This weekend I am going to install an engine guard, and since the right-side exhaust pipe has to come off for that I am also going to replace the discolored pipe with another one that I got last year. The dealer has the crush gaskets in stock, but they are pretty expensive, $9 for the manifold gasket and $17 for the muffler gasket. Do the gaskets from Harley mentioned in the Verses work for OEM pipes too?
Joem is offline
post #2 of 16 (permalink) Old 05-10-2007, 12:03 PM
Crobins365's Avatar
Yep, they work great! And they're easy to come by.
C
Crobins365 is offline
post #3 of 16 (permalink) Old 05-10-2007, 12:25 PM
HAWK
Ccspinner's Avatar
and cheeper, $8 for 2
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 16 (permalink) Old 05-10-2007, 12:40 PM Thread Starter
Joem's Avatar
Is the same model of gasket used at both the pipe/manifold connection and the muffler/pipe connection?
Joem is offline
post #5 of 16 (permalink) Old 05-10-2007, 01:48 PM
Crobins365's Avatar
Wow, as many times as I've pulled my exhaust pipes on and off - and the mufflers - I've not seen any gaskets between the mufflers and the premuffler pipes. Someone else want to jump in? Did I miss a gasket in all this?
C
post #6 of 16 (permalink) Old 05-10-2007, 02:04 PM Thread Starter
Joem's Avatar
I just picked up the HD gaskets over lunch. They are definitely not the same as the one between the pipe and muffler. These are a thin ring. I had not seen them before as I have not had the pipes off before. The one at the muffler is about an inch long and looks like thick aluminum foil. when I switched out my mufflers I reused the ones that were with the exhaust system I bought used. The ones that were on my bikle were stuck and could only be cut off. I think those were the ones the Kaw Dealer wanted $17 for. I am going to see if I can re-re-use the one on the right side before I pick up a new one.
Joem is offline
post #7 of 16 (permalink) Old 05-10-2007, 03:08 PM
BigT's Avatar
Ahhh....I guess that I'm not going to be able to take the engine guard off of your hands huh? Good luck with the install.
I've got my eye on the Wingerline bars, I just have to convince the boss that I really need them.
I smile 'cause I don't know what the h*ll is going on.
BigT is offline
post #8 of 16 (permalink) Old 05-10-2007, 03:41 PM
"ya can't live forever"
artman's Avatar
gaskets
__________________
Hey Cindy !! Yeah there is a gasket that goes around the pipe and fits into the goat belly.It's more like an asbestos sleeve and costs around $15.00.
Heck ya can de-goat for about $25.00 and be done with it.
artman is offline
post #9 of 16 (permalink) Old 05-10-2007, 05:13 PM
Crobins365's Avatar
__________________
Missing a gasket's better 'n blowin' one! I wouldn't have thought that was actually called a gasket, but, maybe "asbestos sleeve." Huh. WHo knew? I have them. On both bikes. I mean, all three. Just didn't recognize it as such.
C
post #10 of 16 (permalink) Old 05-10-2007, 05:42 PM
When I put my H pipe in I used high temp rtv and foil tape no leak at the muffler yet. The hardley gaskets are different but work perfectly as they are woven and compress for a good seal. One of the few things Hardly has that is better.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
