rear cylinder head coolant pipe - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 05-05-2007, 05:01 PM Thread Starter
rider
global_recon's Avatar
okay... still reassembling the bike and i'm having a problem with the rear cylinder head coolant pipe. the end of the pipe which attaches to the engine has a bracket which sticks out and a bolt is used to secure it to the engine. problem is... the hole for the bolt in the bracket is not lining up with the hole on the engine. 99% positive we have the right part... have no idea why things aren't lining up. frustrated. anyone run into this "problem"? as i'm typing this i'm thinking we have the wrong part, but there's nothing else this pipe could be... it fits in the hole... it's the same part as outlined in the clymer manual... the bracket just isn't lining up.
any ideas?
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #2 of 15 (permalink) Old 05-05-2007, 05:29 PM
slim's Avatar
if it is not lining up- up and down make sure there is no old o-ring or anything else in the hole if it is not lining up left and right you may have the wrong tube.
slim is offline
post #3 of 15 (permalink) Old 05-05-2007, 06:05 PM
93VN750's Avatar
The front and rear pipes are different, could they be switched?
The old oring down in the hole is also a good thing to check.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 15 (permalink) Old 05-06-2007, 03:33 AM Thread Starter
rider
thanks for the responses guys. we figured this one out during a dinner break. the guy who's been helping me with the repairs remembered that we'd forgotten to remove this pipe when we first tried to move the engine out of the frame (i'm doing a stator replacement). we figured the pipe had caught on the frame which caused the bracket to bend. all we had to do was hammer the bracket around the pipe a bit and presto... instant 'shorter' bracket and one that lined up perfectly with the hole. seemed so simple once we figured out what had happened.
anyway, thanks again.
paul
post #5 of 15 (permalink) Old 05-06-2007, 04:20 PM
Ah ha, the 'persuader tool' (a hammer) needed to be used. LOL
When all else fails, get the Persuader !!
Food always helps with thinkin'. Glad ya got it figured out Paul
post #6 of 15 (permalink) Old 05-07-2007, 11:57 AM
fergy's Avatar
That used to be one of the main tools for working on a jeep. BFH we called it.
Your acronym mileage may vary.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 15 (permalink) Old 05-07-2007, 03:05 PM
Yeah, that too! And sometimes, the bigger, the better!!
post #8 of 15 (permalink) Old 05-07-2007, 07:08 PM
Uh Huuh, motivator when I was in the USAF.
Foxhound is offline
post #9 of 15 (permalink) Old 05-07-2007, 11:52 PM
How funny, I logged on to ask about the pipe in question as well. I seem to have a leak at the base of the pipe, which I'm sure is a bad o-ring. The question I have is:
How is this pipe attached to the engine?
Is it just the single bolt/bracket on the pipe that attaches to the engine that holds the pipe in the engine and creates a seal? That doesn't seem like it would be effective. I don't want to just haphazardly twist and pull on it if there is more to this than I can see.
Perhaps I should use my Persuader?
bcjoker04 is offline
post #10 of 15 (permalink) Old 05-07-2007, 11:53 PM
Sky Rider's Avatar
A sledge is known as a 20lb fine alignment tool.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
