clutch cover gasket replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-02-2013, 10:02 PM Thread Starter
Could any one give me the simplified instructions on replacing this gasket on my 2006 Vulcan 750?
Fit2BTied is offline
post #2 of 4 (permalink) Old 09-02-2013, 10:12 PM
SlowBox's Avatar
Scrape the old stuff off, wipe with brake clean, apply 'Right Stuff' gasket maker.
SlowBox is offline
post #3 of 4 (permalink) Old 09-02-2013, 10:33 PM Thread Starter
Thanks,that much I did know, do I need to remove the engine or is it just as simple as getting a few things out of the way? (i.e. brake pedal assembly, exhaust)
post #4 of 4 (permalink) Old 09-03-2013, 09:15 AM
the clutch is easy with out removing the engine.. there is a removeable section of frame. you need to remove the brake pedal and foot peg assembly, front exhaust, and the frame section, then the clutch cover can be removed.
