Cracked coolant reservoir - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-27-2007, 05:46 PM Thread Starter
I found a small crack on my reservoir, near the bottom, that I patched for the moment with electrical tape. Anyone know what could of caused this? I have the '89 VN 750 and I'm sure it's never been replaced so age probably had something to do with this but I just want to avoid it in the future if possible.
asaracho is offline
post #2 of 6 (permalink) Old 04-27-2007, 07:13 PM
Crobins365's Avatar
You're probably right about the age thing - it'd be hard for something (like a rock) to get up there and crack it, and there's really no place nearby where you could torque a bolt (like the one that attaches the reservoir tank to the frame) and split the plastic. Electrical tape seems like it might not hold for long, though - Forum members, could one of the sealants work on this? Like the RTV stuff?
C
Crobins365 is offline
post #3 of 6 (permalink) Old 04-27-2007, 07:17 PM
HAWK
Ccspinner's Avatar
Where is the crack, is it by a seam?
You could clean and dry it then try to use a flexable 2 part epoxy would be the best I think.
If you can put some on the inside and outside that would be better.
If you can get the the inside with a stick or screwdriver.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 6 (permalink) Old 04-27-2007, 07:17 PM Thread Starter
I called my dealer today and they are ordering one for me. It only cost 31 bucks so it's not that big of a deal. I love how easy it is to find parts for these bikes!
asaracho is offline
post #5 of 6 (permalink) Old 04-27-2007, 07:23 PM Thread Starter
It's right near the bottom on the right side, not along the seam, on the flat surface. It's definitely old, I can see stress cracks on the top of the tank also. A replacement is definitely needed.
Thanks for the quick suggestion though !
asaracho is offline
post #6 of 6 (permalink) Old 04-27-2007, 09:53 PM
95VN750's Avatar
HOW ODD!!! Mine just sprang a leak too!! right at where you look through to see the fluid level! I did a quick patch with good ol duc-tape..
Only found it when I added water to it to bring it up!
Got replacement from Ron Ayers for 26.10 + shipping.... so while I was at it I ordered the Iridium plugs! 6.70 each and no more shipping cost than the tank alone!
It will be an easy fix... but will do a drain and flush of cooling system while I'm there.
1980 440LTD
1976 KZ900
1995 VN750 19,500 miles ( start of '08 season ) All mine!
Can't have too many Kaws!
95VN750 is offline
