'03 750 found bad cam lobe.... still wont run - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-27-2013, 12:38 PM Thread Starter
Unhappy '03 750 found bad cam lobe.... still wont run
I had recently bought a Vulcan 750 with 9,000 miles on it, I put 3000 on it and started getting misfiring... to the point I was barley running on two cylinders.
So I started the on going project of taking apart the bike, after pulling out the engine I found one of the front cylinder cams was ground down. So I ordered a new cam and filters, then put the bike back together. We had trouble getting it started at first then it ran for about 5 to 10 minutes until we turned it off, the next time we started it up it would barley run, and when it did we heard a shear or chaffing sound ... I am short on time so I was considering getting another engine just to throw in it while the other one is down. Any advice would be wonderful... Im missing the heck out of my bike..
mmerkel123 is offline
post #2 of 5 (permalink) Old 08-27-2013, 12:43 PM
fallow roaches rebuild videos in the stickies of the engine section
post #3 of 5 (permalink) Old 08-28-2013, 11:27 AM
Something destroyed the original cam, and whatever it was probably also destroyed the new cam. If the cam timing is correct, I don't know what it could be, other than a lifter problem. Nothing else touches the cam lobe. I would have suspected and looked for whatever destroyed the first cam before installing a new one.
Oh, did you measure the cam clearance in the head? If it is not as specified, the entire head will have to be replaced, there are no replaceable bearings.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 5 (permalink) Old 08-31-2013, 06:11 AM
Seems like a lot of people are getting similar problem with the bike.
fracsdglna is offline
post #5 of 5 (permalink) Old 08-31-2013, 10:41 AM
Question No Zinc?
I wonder what oil everyone has been using? The removal of zinc was supposed to mean death for camshafts.
