Marbles what a fantastic Idea! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-24-2007, 12:51 PM Thread Starter
OMG! Who ever came up with the Idea to put marbles in the air tubes is a total Einstine!
Lulu No longer goes Vroom POP POP!
LurchChaos is offline
post #2 of 6 (permalink) Old 04-24-2007, 01:02 PM
tankist's Avatar
Send a message via Skype™ to tankist
it is a matter of personal preference i guess, but i'm ok with poping as long as it makes for cleaner exhaust.
for me it is "if you can run cleaner , why not run cleaner?"
Ride Safe
Anton.
tankist is offline
post #3 of 6 (permalink) Old 04-24-2007, 05:54 PM
Rubline's Avatar
How do you get those marbles out?? I plugged the reed valve stem instead of shoving a marble up the hose
Rubline is offline
post #4 of 6 (permalink) Old 04-24-2007, 06:02 PM
fergy's Avatar
You got marbles stuck in the reed valve stem?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 6 (permalink) Old 04-25-2007, 11:16 AM
I actually used someone's approach of using 5/8" copper tubing caps. They fit right over the inlet of the reed valve and the hose slips over it. Completely unnoticible. I do not miss all the popping and especially now with the Cruzer pipes, my nieghbors don't miss it.
ratuck is offline
post #6 of 6 (permalink) Old 04-25-2007, 05:06 PM
Rubline's Avatar
Maybe I misspoke. I plugged the reed stems with a lab quality rubber stoppers. The High heat doesnt effect the rubber. To remove the plugs I just insert a screw and pull the plugs out.
Rubline is offline
