Engine cleaner? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-16-2007, 09:11 AM Thread Starter
Engine cleaner?
Does anyone have any suggestions or warnings for a spray on hose off engine cleaner/degreaser.
Foxhound is offline
post #2 of 6 (permalink) Old 04-16-2007, 09:17 AM
93VN750's Avatar
I use a 1:1 solution of Simple Green if really bad, or 4:1 for general cleaning. Does not hurt rubber or plastics and is 100% biodegradable.
Get engine hot, spray on, let sit, then hose off.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 6 (permalink) Old 04-16-2007, 11:15 AM Thread Starter
Good deal, I use simple green alot. I'll give that a go. Thanks.
Foxhound is offline
post #4 of 6 (permalink) Old 04-16-2007, 01:34 PM
I use Shout the laundry cleaner. It hasn't let me down yet. It's also a very good hand cleaner.
piromedicx is offline
post #5 of 6 (permalink) Old 04-16-2007, 02:29 PM
After cleaning, just be sure to re-lube those things that should be lubed that may come in contact with whatever cleaner you use (moving carb parts, cables .... stuff like that)
countdown= 6
post #6 of 6 (permalink) Old 04-16-2007, 05:22 PM
Uber Member
i just use the car wash stuff, and if i have a really bad spot, i will use dish wash soap dilluted down. i also use a brush with long plastic/nylon bristles to get in all the cracks
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
