Exhuast Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-12-2013, 11:12 AM Thread Starter
Exhaust Help
Just put on the new vance and hines exhaust but I ran into a few issues. I noticed a few threads around that explained the same issues so I wanted to see how common this was. After putting it on I noticed my brake pedal hits. I seen some have put washers in and also some suggested to bend the brake pedal bracket. Is this normal, or did I not install the the right pipe correctly?
Also what do you use to remove the studs from the manifold? I snapped one yesterday and I had extra manifold around and a stud that works but isn't the right one so I want to fix the one that I broke. Any suggestion?
1992 Vulcan 750.
Ear shaved and re-jetted.
theone2043 is offline
post #2 of 7 (permalink) Old 08-12-2013, 11:32 AM
R/R = Relocated Redneck
Jakzen's Avatar
Lots of this
And one of these (stud remover)
May need to add a little heat to expand the manifold and relieve pressure in the stud.
ID:	10129   Click image for larger version
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #3 of 7 (permalink) Old 08-12-2013, 11:36 AM
The brake pedal should clear without a problem. Did you take the pedal bracket off 1st to fit the pipe up? Studs you just gotta soak in WD-40 or PB blaster. Sorry I don't have an extra manifold for you.
post #4 of 7 (permalink) Old 08-12-2013, 11:54 AM Thread Starter
No I didn't take the pedal off I just slipped it under it. I still had my original manifold around with the broken stud removed - yes two manifolds that I managed to snap the same stud. I don't recall how I got that broken stud out and the new stud I had gotten from the dealer wasn't the right seems a little longer. So right now I'm using the wrong stud and I'm thinking that's the issue. I'm going to see if I can take off the one good stud and use instead of the one the dealer gave me. Where can you get the stud remover?
1992 Vulcan 750.
post #5 of 7 (permalink) Old 08-12-2013, 01:07 PM
Most hardware or some automotive stores would stock metric Manifold bolts....just math the threads & size up.
post #6 of 7 (permalink) Old 08-12-2013, 03:42 PM
Jakzen's Avatar
Sears or most auto parts stores. I believe they make multiple sizes, I got the one I have to remove a broken wheel stud on a old scout (frickin lefty threads)...
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
post #7 of 7 (permalink) Old 08-12-2013, 06:49 PM Thread Starter
Did some more testing and it seems like the heat shield is whats causing it to hit. With that off no issues. I tried to tighten the sheild down but same thing.
1992 Vulcan 750.
