Left-Side Crankcase Leakin' Oil Like A Sieve - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 08-12-2013, 02:41 AM Thread Starter
Bobber Junkie
Madame Mohawk's Avatar
Send a message via Skype™ to Madame Mohawk
So, the title pretty much says it all, but allow me to elaborate...
This is not a new leak. I've had Thunder for about two years now, and she's been leaking for at least a year and a half. Since she's been called back into service, it has gotten worse, little by little. We've put in Stop Leak and it didn't even touch it. Thought the crankcase cover may be loose, so Doomsday attempted to tighten the bolts today (cause, yanno, he's stronger n' me and all)...
...and discovered at least one bolt had been stripped previously. The tightening seemed to have just made things worse; she seems to be leaking twice the amount of oil now. I'm thinking it's the gasket, as there has also been little bits of rubber protruding from the crankcase for some time, but I am not confident enough in my mechanical prowess to attempt a repair myself. So, can any of you fellas tell me, what year I need to ask for when I go order this gasket and what size bolt I'll need? Yes, I will order a pair; if one sides' shot, I'm sure they both are. I know a very good mechanic that has worked on two of our Kawis before, and he's close to our place. She'll be in good hands until I learn what I need to and flesh out my toolkit more completely.
Or, if you guys have another suggestion or know what else may be causing this problem, please let me know. I know many of you have been wrenching on these beasties for a long time and I trust your knowledge. Thank you for any insight you can impart!
This is my Vulcan. There are many like it, but this one is mine.
Thunderhorse 86 VN-750
Single mirror conversion
Cafe bars
New forks, lowered (Thanks Deuce!)
VN-900 seat (Them hips don't lie!)
Vintage bags
Gas mask 'fairing'
Radiation symbol on tank
On the list
Earshave/rejet
Underglows, light bar
Custom paint
Radiator cover
Pipes
Turn Signals
Grips
Horns
Fixing that damn oil leak
Madame Mohawk is offline
post #2 of 23 (permalink) Old 08-12-2013, 06:45 AM
BeeSea's Avatar
Would that be the side the clutch cover is on? Is it just the clutch cover or is it the whole side? I use this website http://www.kawasakipartshouse.com/oe...2/engine-cover
to get part numbers and then I go to my local kawasaki place to order. But I did use a cereal box with great success on a smaller gasket, and although I am a girl and only been wrenching on this bike, I feel able because of all the help here and the great video that roach did on how to assemble the engine.
BeeSea
1986 750 Vulcan
Relocate R/R to side cover
Re-did the engine
from the case up.(And it runs)
YOU CAN TOO!
BeeSea is offline
post #3 of 23 (permalink) Old 08-12-2013, 08:01 AM
Madame's leak is on the left side (as you sit on the bike), Stator/Damper Cam Gear side.
The clutch is on the right side.
post #4 of 23 (permalink) Old 08-12-2013, 08:40 AM
BeeSea's Avatar
Lol see? Great help.
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #5 of 23 (permalink) Old 08-12-2013, 11:07 AM
nopickles98's Avatar
I never use that stuff (anymore). Sometimes it stops the leak, sometimes it stops up more than the leak. you may have clogged one of the tiny oil lines and in turn increased oil pressure causing the leak to worsen. Used it in my first car radiator, 1973 Maverick (Grabber cause I was cool). had to back blow the heater core cause of that stuff. Easy fix but it I was cold for a few days and had to replaced the radiator anyway. I suggest you blow out the oil lines when it's apart. Also, tightening bolts past the torque spec risks stripping it as well as other problems depending on which bolt it is.
Good luck - hope you get 'er back on the road soon!
I don't wanna pickle......
I just wanna ride my motorsickle.
Arlo Guthrie
http://www.youtube.com/watch?v=g266Uwp6ZnI
'98 VN750
purchased Nov 2012 w/ <8,000mi
previous plate (last time on the road legally) 2002 therefore.......
carb rebuild
AGM & Iridiums
R/R relocation
Kury voltmeter
Splines lubed & in excellent shape
Aug 2013 - new Shinko 230 TM oversized front & rear
Finally got'er shaved
nopickles98 is offline
post #6 of 23 (permalink) Old 08-12-2013, 11:17 AM
Doesn't matter what year you ask for because they are all the same. Most just ask for 2006 because dealerships will hassle you if your bike is more than 10 years old. That being said, for your stripped out bolt I'd suggest putting in a helicoil or re-tapping the next largest size (helicoil is a better fix IMHO because you gain structural integrity).
post #7 of 23 (permalink) Old 08-12-2013, 11:24 AM
R/R = Relocated Redneck
Jakzen's Avatar
I believe that the gaskets will be the same for all of the 750's. As far as the bolt? Depends on whether the bolt or the hole was stripped (most likely the hole...aluminum case vs steel bolt). If its the hole, you may be able to get away with packing it with jbweld and re-tapping it. If its the bolt, you can try chasing the threads with a tap and replace the bolt. Stock bolts for the case are 6mm-1.00 (the tap is the same size regardless of which way you have to go). The length will most likely vary, but you can get a replacement at a hardware store, just take the original with you to compare.
Over torqeing the bolts will cause the gaskets to bulge and possibly fail. Try to follow manufacturers recommendations when it goes back together.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #8 of 23 (permalink) Old 08-12-2013, 11:36 AM
... there has also been little bits of rubber protruding from the crankcase for some time,...
Could it be leaking from the outer stator cover? That cover does have a rubber o-ring type gasket. This would mean only three screws to replace that gasket, without pulling the engine off the frame.
Otherwise the rubber must mean someone has re-sealed the inner stator cover and used silicone at some point.
If you get the inner stator cover gasket done, you should also replace the shifter shaft seal, for a few bucks more.
post #9 of 23 (permalink) Old 08-12-2013, 01:00 PM
x2
post #10 of 23 (permalink) Old 08-12-2013, 01:14 PM Thread Starter
Bobber Junkie
Haha, waking up to so many answers about this, I feel like a kid at Christmas! At least it sounds like it'll be an easy enough fix...though now I'm feeling that the Stop Leak was a real derp move. Could one hand-tighten the bolts past factory specs? I don't have an impact wrench or anything; it was all done with manual hand tools.
Thank you guys (and gal; Bee, you ROCK! Needs to be more girls riding AND working on bikes, IMO!) for all the answers thus far; gives me a good jumping-off point!
Cafe bars
Vintage bags
Gas mask 'fairing'
On the list
Earshave/rejet
Custom paint
Radiator cover
Pipes
Turn Signals
Grips
Horns
